Changing SU shaft https://www.ausmini.com/forums/viewtopic.php?f=2&t=24928 |
Author: | GT [ Wed Nov 15, 2006 7:03 pm ] |
Post subject: | Changing SU shaft |
Anyone replaced the main shaft in an SU? I am worried that if I undo the nut on the side, to extract the shaft, I will not remember the positioning of the throttle linkage. Does the throttle linkage go back in one spot only, or does the nut hold it in place, and you adjust it to suit? |
Author: | drmini in aust [ Wed Nov 15, 2006 7:07 pm ] |
Linkage fits only 1 way. Most important thing is setting the butterfly back in the same place- fit it the same way, do screws finger tight only, hold up to light and look thru it to make sure it's not got daylight anywhere. Then tighten screws. open and shut it, make sure not catching. ![]() |
Author: | willy [ Wed Nov 15, 2006 7:07 pm ] |
Tip... don't tighten it up too tight... **** brass ![]() ![]() There are two flats on the shaft.. which the wheel or linkage slides onto... you can get it either right; or really wrong ![]() |
Author: | GT [ Wed Nov 15, 2006 7:11 pm ] |
aaahhhhhhh cheers! was going to do it tonight, if I can knock off work stuff first ![]() ![]() |
Author: | drmini in aust [ Wed Nov 15, 2006 7:15 pm ] |
Use NEW Butterfly screws, and stake em. ![]() |
Author: | gafmo [ Wed Nov 15, 2006 7:20 pm ] |
take a picture before hand for Referance ![]() |
Author: | GT [ Wed Nov 15, 2006 7:21 pm ] |
yea got new shafts, butterflys and screws |
Author: | Matt68 [ Thu Nov 16, 2006 9:04 am ] |
If doing twins, do one side at a time for an easy reference from the other. When rebuilding mine for the first time, I took about 24 photos in various states of dissassembly for reference when rebuilding. Got the film (remember film? ![]() Now it is a matter of memory. You could consider using loctite on the butterfly screws. The bits that stick out are the worst things for flow! Then, you might not want to take the risk of losing one into the motor ![]() |
Author: | GT [ Thu Nov 16, 2006 10:08 am ] |
cool ![]() i am doing this tonight. i was thinking about loctite on those screws. should i use hard or soft gasket goo when reassembling? |
Author: | Gadgets mini [ Thu Nov 16, 2006 3:30 pm ] |
GT wrote: cool
![]() i am doing this tonight. i was thinking about loctite on those screws. should i use hard or soft gasket goo when reassembling? just dont get any on your Hootus ![]() also take step by step photos so that you can pen a "How to" Thread in your copius amounts of free time BTW if you need the addy of a good website to post it to as well as here you could try http://s3.phpbbforfree.com/forums/justanothermini.html ![]() |
Author: | Matt68 [ Thu Nov 16, 2006 5:38 pm ] |
GT wrote: cool
![]() i am doing this tonight. i was thinking about loctite on those screws. should i use hard or soft gasket goo when reassembling? I have always been told to use fresh gaskets and don't use a gasket goo. Never had a problem (with that anyway!) Otherwise I'd go soft, petrol resistant gasket goo if you need too, but just a very thin bead. Cheers matt |
Author: | GT [ Mon Nov 20, 2006 8:55 am ] |
Reassembled one carb the other night. Looks brand new. The shaft was piss easy to swap. Just as well I did it too, as the old one was VERY worn! ![]() I am doing the other carb 2nite ![]() |
Author: | smac [ Mon Nov 20, 2006 9:45 am ] |
Out of interest, do mind saying where you got the parts and how much? I have a couple HS6's sitting in need of new butterflies (run-on valves have been butchered out of them). |
Author: | GT [ Mon Nov 20, 2006 10:09 am ] |
no probs ![]() http://classicmotoring.net.au/cmos/inde ... th=1_50_52 |
