Vinly Spray Paint https://www.ausmini.com/forums/viewtopic.php?f=2&t=24953 |
Page 1 of 2 |
Author: | Fiji [ Thu Nov 16, 2006 12:50 pm ] |
Post subject: | Vinly Spray Paint |
Vinyl Spray paint - can u get it easily & where. cheers |
Author: | Lillee [ Thu Nov 16, 2006 12:53 pm ] |
LOL i knew you'd post it here. Check out bunnings. I am sure I saw some white knight stuff that was for plastic/vynl. Another place to try is Clarke Rubber. Good luck let us know how you go |
Author: | Fiji [ Thu Nov 16, 2006 12:57 pm ] |
lol. be running around today for it cheers bud . i thought i had posted it already.... |
Author: | Dave Elliott [ Thu Nov 16, 2006 2:12 pm ] |
SuperCrap had it the last time I was there |
Author: | dove grey 64 [ Thu Nov 16, 2006 3:10 pm ] |
and autobahn |
Author: | badassmini [ Thu Nov 16, 2006 4:51 pm ] |
supercheap, autobarn, repco they all have it i bought a can about a month ago VHT brand it was but theres others to. |
Author: | Angusdog [ Thu Nov 16, 2006 5:48 pm ] |
Do not get the gloss stuff as it is really shiney and looks silly (if you're recoating seats). It seems hard wearing and easy to do. I used Vinylcote (or something spelled quite similarly). |
Author: | slinkey inc [ Thu Nov 16, 2006 7:37 pm ] |
The last owners of my car who obviously wanted a black roof and black vinyl seats just used normal matt black spray paint! ![]() |
Author: | Mike [ Fri Nov 17, 2006 1:27 am ] |
I've done it a few times once it came out crap but the next two times it was better and better. DONT buy the white knight crap from Bunnings - its not a propper dye and is a pain to pait properly, gets hardly any coverage and wears off. I've used it the first time but then switched to the VHT Vinyl dye from Repco (about the same price) and it was much much better. Gloss black can be used but you just have to be far more meticulous than with matt black as the gloss black makes any defect stand out (just like car painting). You'll need about 1 can for the two parts of the mini rear seat if you want to achive decent coverage and dept. The key is to make sure that the vinyl is as clean as possible and there's no dust. Then use many many light powdery coats rather than a few thick coats that'll run. Hang the items in a garage at a comfortable height and with light falling on them so that you wont have to touch the actual vinyl surface untill its fully dry. As the dye doesnt cover the channels in the stitching and the piping and the corners as well as the flat sections I first try to get the dye into all those channels with vertical sprays a bit closer and thicker than with the rest of the surface - you can be more agressive with the spaying here and use thicker coats to get penetration as the later general coats over the entire surface will blend the whole thing in. After several coats to get into the little chennels and the stitching grooves start applying the dye in even slow passes on the entire surface. Wait between each coat the time that is stated on the can (5-10mins?) Again light powdery coats are much better than thick ones. It'll seem like you havent covered anything on the first few passes but you'll start seeing results a few coats later and this way you'll get more coverage out of each can. |
Author: | Spaceboy [ Fri Nov 17, 2006 3:48 am ] |
buy dye not paint |
Author: | supercharged 850 [ Sat Nov 18, 2006 12:13 am ] |
Ive seen a standard headlining sprayed in regular matt black paint, and it looked 400 times better than using vinyl spray (cheaper too) |
Author: | Fiji [ Sat Nov 18, 2006 7:00 am ] |
cheaper.. just want the better product... knowing mates... they'll start testing how easy to rub off in no time, then i'm back doing it again. i'll look for a dye. cheers. |
Author: | slinkey inc [ Sat Nov 18, 2006 10:11 pm ] |
supercharged 850 wrote: Ive seen a standard headlining sprayed in regular matt black paint, and it looked 400 times better than using vinyl spray (cheaper too)
Yeah I agree. You can't even notice that it's not 'vinyl' paint. And it sticks and doesn't require any extra effort. Just paint it like you were painting any other car aprt in matt black. |
Author: | Spaceboy [ Sat Nov 18, 2006 10:44 pm ] |
Author: | slinkey inc [ Sun Nov 19, 2006 8:48 am ] |
I think this 'vinyl' paint might be a case of marketing. You see I rember at supercrap when I got some primer they guy asked me do you want 'acrylic primer' or 'sandable primer'? I said "Yeah i want acrylic but that's sandable anyways.... ![]() |
