It is currently Wed Jul 30, 2025 9:32 am
PostPosted: Mon Nov 20, 2006 9:03 pm
As per title..
is there anyone about the traps who can check out a car for me?
It's not a Mini, but a Statesman.
All I am after at the moment is pictures.
If you can do the favour for me, that would be great.
PM me if this sounds like you :P :D
PostPosted: Tue Nov 21, 2006 8:01 am
Victorians?
PostPosted: Tue Nov 21, 2006 8:07 am
*sigh*
PostPosted: Tue Nov 21, 2006 8:58 am
willy,
I don't live in that area but I will be in the vacinity next week some time for a few days work, so I may be able to help you out if you don't get a better offer.
Tim :)
PostPosted: Tue Nov 21, 2006 9:31 am
willy how old are you again......
First a Magna then a Statesman!!!
We'll have to book you into a retirement place soon!!!
Bring on the cardigans!!!
PostPosted: Tue Nov 21, 2006 9:36 am
Reasons:
It's a Holden... parts are plentiful - as are Mitsi parts
It's not a Commodore... It won't be lowered/full sick-ed up.
It can tow
It's an every day car
It has the things I want... cruise control, power windows, air con.
Now where's my bowls hat?
edit: ****ing stereotypes.
PostPosted: Tue Nov 21, 2006 10:43 am
I reckon you should have a look at one of these, I always see them parked at the bowlng clubs..
http://vintagecars.about.com/b/a/256883.htm
Or, you could get a car with your name already on it:
http://www.public.asu.edu/~grover/willys/ws.html
PostPosted: Tue Nov 21, 2006 11:20 am
If either car has coil springs in the rear, then they are a bad choice for towing.
I have a commodore which has a coil spring rear. The original tow bar mounting was too low for all but box trailers and we increased the height. With a car trailer that put more weight on the rear and the coils compress more. The coils dont compress equally or in the same direction (they bow) and rebound in unanticipated fashion.
Also the weight on the rear sticks the nose up fairly high and even under fairly moderate braking its difficult to get enough weight transfer to get good front wheel braking effect. Coming home from MDU I had one case where a kangaroo wanted to argue road space and the commodore had both front wheels locked being pushed along by the trailer. And... that was with very light pedal pressure, not a both feet on the brake pedal panic stop.
If you want a tow car - then you dont want a rear coil springs car. I know modifying the suspension will made a world of a difference but - in my case I tow occasionally, I drive the car a lot - it already has enogh rattles from the rough country roads.
PostPosted: Tue Nov 21, 2006 11:37 am
I will probably be towing a Mini once a month, if that, and a small boat every second weekend.
So not much towing at all... but still towing none the less.
