air horns, where can they fit
https://www.ausmini.com/forums/viewtopic.php?f=2&t=25112
Page 1 of 2
Author:  buztoy [ Mon Nov 20, 2006 6:02 pm ]
Post subject:  air horns, where can they fit
i consider this a safety issue aswell as a road rage issue, i need L320mm and W180mm and H 120mm,
the mini is too low to have them underneth, the horns are too big to get them in the wheel cavity, i was thinking about hanging them from the bonnet on the structrual part on the drivers side, but might have an issue with that starter relay
Author:  pristic [ Mon Nov 20, 2006 6:08 pm ]
Put 'em on the roof like a Mack truck :lol:
Seriously, they are pretty big... can you make a bracket for them to sit above the clutch cover and to the left of the engine. (Unless you have a booster.)
Turn them vertical and bolt to the left firewall (maybe move wiper bottle if its in the way)
Or, like you said, on the bonnet ... just replace the wiring and put something longer and use a tube that normally goes over the wire on the door speakers (sits in between the door and the car)
Peter.
Author:  sports850 [ Mon Nov 20, 2006 6:10 pm ]
I've fitted them in the drivers side guard of a clubbie , facing forward with the open end tucked in behind the headlight (not facing back as that's the direction the water comes from ) , on the bonnet support panel facing diagonally down and facing down and also on the drivers side inner guard between the subframe tower and the washer bottle or overflow tank if fitted there .
Author:  Morris 1100 [ Mon Nov 20, 2006 6:12 pm ]
I use a pair of Lucas electric horns. (don't laugh)
They are quite loud when properly tuned. :shock:
Author:  drmini in aust [ Mon Nov 20, 2006 6:15 pm ]
My Fiamms (ex Fiat 124S) fit nice in the LH arch, facing down and forward. Room for the Toyota washer and pump too. 8)
Author:  sports850 [ Mon Nov 20, 2006 6:20 pm ]
You could always mount them under the boot so people always glare at the car behind you for blasting the horn ....
Author:  buztoy [ Mon Nov 20, 2006 6:25 pm ]
i had a similar idea, i was going to get those(you find them at wrecker garenteed) plastic electric horns,
"dont you smile at me love", thats not stress thats road rage
Author:  Morris 1100 [ Mon Nov 20, 2006 6:25 pm ]
I just shrug my shoulders and point at the car behind me. :twisted:
Author:  buztoy [ Mon Nov 20, 2006 7:19 pm ]
ian and pristic win the boobie prize which is a cartoon smilie faces, :D :D :D :D :lol:
im going with the spot next to the washer bottle, does anyone know how much that clutch can move, mines disasembled,
Author:  Mike_Byron [ Mon Nov 20, 2006 7:29 pm ]
I mounted mine using a self made bracket that bolted to the front end of the sub-frame. In the space between the engine and the sub-frame. Been there many years now and is functional
ps - its a clubby.
Author:  buztoy [ Mon Nov 20, 2006 7:32 pm ]
between the dissy and the grill?
Author:  9YaTaH [ Mon Nov 20, 2006 7:38 pm ]
Post subject:  Lucas
Hmmmm smoke powered horns :!: I agree with Buztoy....angled slightly down and away so that they don't get splashed..and I hope they are LOUD :shock: 8)
Author:  buztoy [ Mon Nov 20, 2006 7:43 pm ]
it kind of follows that same idea,
the idea about the horns was that i was in a carpark and a lady in a 4wd just zommed out in front of me, went to smash that horn botton off that idicator stalk and i hear,
2secs later after i pushed it" (mmmmeerrrrrr) very quietly sounded,
Author:  HPDesign [ Mon Nov 20, 2006 8:06 pm ]
those are the type that need an external compressor. Do your self a favour get the $30 from Supercheapand because their seperate their heaps easier to fit under a wheel arch etc.
with those ones you need a compressor and a chamber, their basically off a truck, and need a nuch higher pressure than the ones off poopercheap
Author:  drmini in aust [ Mon Nov 20, 2006 8:55 pm ]
If you have a choice, avoid the plastic trumpets- metal ones sound heaps better. 8)
