kazjim wrote:
Kev, put me down for a "possible" set of imps....
I got a spare 998 block here just itching for the 1100 Crank to go in.......
What sort of dish do they have ? if i left it "undecked" (just enough to true it up) would it have less than, say, 8:1 compression with a 12G202 head ?
Or while I've got the block apart, should i just pocket and stick that thumping great 12G940 head on ?
WIll probably get another "russell" cam maybe with a little less inlet duration and maybe a little more exhaust, as well as hopfully making a larger exhaust manifold ........
thinking, thinking, thinking.......
J
All Imp pistons were flat top, flycut for the inclined valves. No big deal.
2 types sold here, std Imp and Imp GT. Only diff I can see is the GT had thicker wall gudgeon pins. Both types have the gudgeon pin offset so watch how you fit them..
Deck height is about .140" or so less than a 1098 one, so if you are building a N/A motor mill a chunk off the block. I guess for turbo you could leave 'em down the bore a bit.
When I built mine back in `68 I notched the block and ran a 12G940 (1100S) head, with a 544 cam and twin HS4s. The thing screamed- 8500 was no big deal. Until I broke a piston circlip.... bore got scored big time, and the fun came to an end.
<edit> Fit teflon (PTFE) buttons instead of circlips if you're gonna rev it hard..
I then fitted a 1275 motor in, but it just didn't go the same.
I'd just use stock 1100S valve sizes- or maybe fit S inlets. Stocko exhausts.
