Mike_Byron wrote:
But........ fix the fundemental overheating probem first. It is always one of three problems.
a. Lack of circulating coolant volume (blocked radiator, crud in system etc)
b. Lack of coolant circulating ( worn water pump, crud build up, wrong or seizing thermostat)
c. Tuning issues (too lean, ignition timing problems)
On this note, what is the best way to clean the system. I have had the rad off and flushed until the water ran clear, I stuck a hose in the thermostat housing and ran it until the water ran clear from the tope hose inlet. I ran a rad flushing fluid (admittedly last year) for a couple of weeks and then flushed.
Yet still, my Mini was getting pretty hot yesterday sitting in traffic at 36c and climbing the big hill to home so I had to put the heater on which helped a lot, but didn't do me much good!!
I have a thermo fan fitted under the wheel arch, right next to the rad, but this just seemed to make it worse not better when I switched it on (and it is the right way round).
I have a Pulsar dizzy and am pretty happy with the timing.
My next step was the heater matrix mod mentioned above. I can't afford a fancy new/big radiator so what else should I do. I need to get to work and back through the summer!
Rick
