It is currently Mon Jul 28, 2025 12:07 am
PostPosted: Sun Nov 19, 2006 5:21 pm
Are there any early clubman floor panel reproductions out there? I have the newer replacement floor panels, but the fit isn't all that great. I can make them work, but would be interested if someone had the floor panels that have the hydrolastic chanels and remote bulge in drivers side.
PostPosted: Sun Nov 19, 2006 6:22 pm
Try A Grade Panels in Melbourne. :wink:
None of the UK made ones have these channels. :cry:
PostPosted: Tue Nov 21, 2006 2:29 pm
Yeah, I might just cut a slot where they fit in and get a few bits of Zintex bent to size and tig em in, might be easier. Going to give it a bash on the weekend after welding in Ed's rear end.
PostPosted: Tue Nov 21, 2006 9:41 pm
I cut the l/h floor out of a clubbie at pick and pay with a battery drill and cold chisel. Left enough to trim and fit , then had it welded in .
68 Deluxe. All the Options and Mods. Bling-Bling.
PostPosted: Wed Nov 22, 2006 7:58 am
Elmo, either you drilled ALLOT of holes or you went nuts with a cold chisel, surely the panel would have been deformed with all the beatng?
