It is currently Sat Aug 02, 2025 1:45 am
PostPosted: Tue Nov 21, 2006 10:26 pm
I want to remove the hinges on the A-Panel side. the nut furthest the firewall is no problem, but the one closest to the firewall is something crazy to try remove. Any ideas trhat may help would be apreciated. Thanks....
PostPosted: Tue Nov 21, 2006 10:39 pm
Socket with angly gizmo works every time for me. But it is a bugger of a job.
I can only please one person per day,
Today is not your day,
Tomorrow is not looking good either.
PostPosted: Wed Nov 22, 2006 5:41 am
A short Sidchrome 7/16" ring/OE spanner with the ring end severely ground down in diameter.
And with the offset angle bent a bit. :wink:
PostPosted: Wed Nov 22, 2006 6:58 am
i found an el cheapo brand rachet that fits in there no probs
PostPosted: Wed Nov 22, 2006 7:34 am
Hmmm, I have a 7/16 sidchrome, will try it on the grinder nice and slow, don't want to heat it too much. If that doesn't work, i'll cut it off and replace the inner and outer A-panels as this has to be done anyways. Thank gawd for TIG and new panels.
I have found a fair bit of nicely hidden rust in Ed, first off he was a very straight car, now I'm finding bog city. At least I am doing it right first time and replacing bog with steel cuts, bloody bog merchants should have been shot. I'v actually found a fair bit of lead wiping also, that amused me.... :?
PostPosted: Wed Nov 22, 2006 7:41 am
Just go to supercheap or bunnings and get a budget 7/16 socket to bastardise instead of your sidchrome , doesn't matter if you go too far and damage it then ....
PostPosted: Wed Nov 22, 2006 8:06 am
My Sid's are my cheap set, its my Gedore set that does me proud. :wink:
In saying that, I will go get a cheap ring from repco and grind that.
 Post subject: door hinges
PostPosted: Wed Nov 22, 2006 8:25 pm
Like DrMini, I have ground down a 7/16 ring and it served its purpose but I now have a 1/4 drive socket set that works admirably in the confined space.
 Post subject: right tool
PostPosted: Wed Nov 22, 2006 8:30 pm
Use a ratchet and 1/4 or 3/8 flexidrive behind your socket...piece of cake :!:
PostPosted: Sun Nov 26, 2006 5:29 pm
LOL, I used my flexi drive and found the nuts to be so rusted into place, I had been spraying them with WD40 over the last few nights to try make it easier, but ended up rounding off the nuts, they wouldn't budge, and that was with a new socket. So I removed them the easy way, got the very slim cutting disc out and cut through the A-Panel a slight angle and cut the shank of the bolt. Whalla... presto, its off!!
