It is currently Thu Aug 07, 2025 6:52 pm
 Post subject: shaft size
PostPosted: Wed Nov 22, 2006 8:00 pm
What is the size in mm of the shaft size of a normal mini steering coulm :?:
cheers :D
PostPosted: Wed Nov 22, 2006 8:15 pm
Hot off the vernier, 22mm.
PostPosted: Wed Nov 22, 2006 8:51 pm
that tile sounds hmm interesting! :lol:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Nov 22, 2006 9:50 pm
so just confirming the size is 22mm ?
PostPosted: Wed Nov 22, 2006 11:06 pm
can anyone confirm it? Its just I need to know to order a Boss kit for a steering wheel
PostPosted: Thu Nov 23, 2006 7:25 am
Interesting indeed and easily taken the "naughty" way hehe .... so how big is a mini shaft??
PostPosted: Thu Nov 23, 2006 7:51 am
In that case then just tell them it's for a mini , other cars have the same diameter shaft but different pitch splines .
PostPosted: Thu Nov 23, 2006 8:37 am
otherwise put your wheel on a piece of paper, mark out all the lines and holes, ane fax it to minisport, and theyll look after it!
1360 ls
the more u stroke it the biggerit gets
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
 Post subject: shaft measurement
PostPosted: Thu Nov 23, 2006 7:52 pm
For those with the devious bent, a vernier is an accurate measuring instument and the shaft diameter in metric terms is 22mm.
 Post subject: shaft diameter
PostPosted: Thu Nov 23, 2006 8:03 pm
PS. Having re-read the thread, I see that the size you are really after is the spline end so I have just measured again and it is 18mm. If a boss kit is all you need, the firm you are dealing with should have the nous to supply you with the correct one. I had no trouble in getting one from autobarn.
