shaft size
https://www.ausmini.com/forums/viewtopic.php?f=2&t=25182
Author:  aussie [ Wed Nov 22, 2006 8:00 pm ]
Post subject:  shaft size
What is the size in mm of the shaft size of a normal mini steering coulm :?:
cheers :D
Author:  64cooper [ Wed Nov 22, 2006 8:15 pm ]
Hot off the vernier, 22mm.
Author:  mad-mk1 [ Wed Nov 22, 2006 8:51 pm ]
that tile sounds hmm interesting! :lol:
Author:  aussie [ Wed Nov 22, 2006 9:50 pm ]
so just confirming the size is 22mm ?
Author:  aussie [ Wed Nov 22, 2006 11:06 pm ]
can anyone confirm it? Its just I need to know to order a Boss kit for a steering wheel
Author:  1360 LS [ Thu Nov 23, 2006 7:25 am ]
Interesting indeed and easily taken the "naughty" way hehe .... so how big is a mini shaft??
Author:  sports850 [ Thu Nov 23, 2006 7:51 am ]
In that case then just tell them it's for a mini , other cars have the same diameter shaft but different pitch splines .
Author:  mad-mk1 [ Thu Nov 23, 2006 8:37 am ]
otherwise put your wheel on a piece of paper, mark out all the lines and holes, ane fax it to minisport, and theyll look after it!
1360 ls
the more u stroke it the biggerit gets
Author:  64cooper [ Thu Nov 23, 2006 7:52 pm ]
Post subject:  shaft measurement
For those with the devious bent, a vernier is an accurate measuring instument and the shaft diameter in metric terms is 22mm.
Author:  64cooper [ Thu Nov 23, 2006 8:03 pm ]
Post subject:  shaft diameter
PS. Having re-read the thread, I see that the size you are really after is the spline end so I have just measured again and it is 18mm. If a boss kit is all you need, the firm you are dealing with should have the nous to supply you with the correct one. I had no trouble in getting one from autobarn.
