It is currently Mon Aug 18, 2025 7:50 am
PostPosted: Thu Nov 30, 2006 11:53 am
The heater on my cubman doesnt work. I can select the air to flow into the screen or car and turn it on and off etc but i can not select warm / cold as the switch will not move. any ideas? thanks!
Also does anyone know any mini stores in the sydney/ wollongong areas? thanks, cahn
PostPosted: Thu Nov 30, 2006 12:13 pm
Die Die Die!!
all i can say is that its a common problem... could tell you how to fix it tho...
PostPosted: Thu Nov 30, 2006 12:14 pm
The heater tap - it's on the other end of the hot/cold slider control is gummed up with years of crud etc from water/coolant.
It's practically impossible to get to it without actually removing the heater unit from your car.
There's a nut and bolt at the top of the heater unit and two more at the back - you have to remove these 3 plus the 2 heater hoses but before you do, peel back the carpet because rusty water is bound to come out and leave a stain.
Anyway, get the unit out of thew car and pull it apart - you can then get rid of all of the dead insects and leaves which are bound to be in there.
Get the the actual heater tap thing and remove the hoses - now just work on it, with WD40 or whatever till it's working again - then re-install.
Alternative for you is to leave the control on so that the heater is always 'on' - the advantage is extra cooling for your mini....it works :)
Hooroo
Rod Image
PostPosted: Thu Nov 30, 2006 12:20 pm
or you can remove the heater tap and plumb the hose straight in if you cant afford a new tap or in most cases the tap is rusted up bad
PostPosted: Thu Nov 30, 2006 12:57 pm
thanks alot.. ill try and get it out and clean it...
yeah my dad told me i could leave it on to cool it down, he has had his share of minis!!!
thanks again!
PostPosted: Fri Dec 01, 2006 4:00 pm
Did the same thing with mine - the price for a new tap is ridiculous so just plumbed the hoses straight back into the core. Cools very very well but a bummer in summer...lmao. can be an issue in winter too but thats why I put perspex behind the grille to get the temp up in winter.
Hooroo
Rob Forsyth
Miniot!!
 Post subject: mini stores
PostPosted: Fri Dec 01, 2006 6:58 pm
try Car Kraft Silverwater also there is Mini Clinic Padstow. There is also on in Seven Hills but sorry can't remember the name and one in Castle hill. Best thing to do is check the mini mags for listings.
Hellooo from OODLES my mini. Is being restored to be revealed in all her glory one day in the future she looks forward to meeting you all.
PostPosted: Fri Dec 01, 2006 7:07 pm
Holden and Ford both used cable operated heater taps, you can pick them up fairly cheap from a good spare parts store.
PostPosted: Fri Dec 01, 2006 10:57 pm
The tap to the heater core only courses more problems than its worth
As mention above just take out the tape and direct the hose directley into the core of the heater.
It will give you more sirculation during the summer months with little discomfort. If you require the additional colling fot he engine just turn the fan on. You will heat uo but the engine will cool down 8)
The tap is just additional area for rust and problems and possile hot water at your feet when you don't want it :?
PostPosted: Sat Dec 02, 2006 12:18 am
i've used a holden tap, which is plastic btw, but no means of mounting it easily as its the wrong shape, therefore the switch panel didnt work and i had to bend down to manually flick it
PostPosted: Sat Dec 02, 2006 8:37 am
thanks again!
You could try this idea-fit a on-off valve directly into the heater hose from your cylinder head.Works good,at least you can manually turn the heat on or off 8)
PostPosted: Sat Dec 02, 2006 8:55 am
are you from wollongong?
If so garry from revolutions race gear in wollongong can get you any parts you need!
Also if you are in wollongong check out www.minisinthegong.com.au
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
Users browsing this forum: goodie and 300 guests
