It is currently Sun Aug 17, 2025 1:26 am
 Post subject: z
PostPosted: Fri Dec 01, 2006 7:08 pm
zz
PostPosted: Fri Dec 01, 2006 7:19 pm
LordCruiser wrote:
2. What's the compression pressure for the 1098? It ain't in my abridged workshop manual.
Compression pressure is a variable. It depends on a lot of things. You can test an engine one day and have a different pressure the next. If you have a bigger overlap cam you will get less pressure on a gauge.
My 1100 has around 125psi in each cylinder. :wink:
PostPosted: Fri Dec 01, 2006 8:18 pm
A normal compression would be around 140-150 psi , my 1098 has 175 psi on all cylinders , but it has had some work done to the head . Think pollution motor is lower , around 135 psi
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
