How wide are your seats?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=25423
Author:  Mini Mike [ Wed Nov 29, 2006 9:38 pm ]
Post subject:  How wide are your seats?
Looking at buying some after market seats I have the dimensions of the seats but im not sure they will fit. So I need to know how wide is to wide? I know Hanra has some sparcos. Who else has some? Those that do could you please grab the tape measure for me and have a quick look ide really appreciate it...
Mike
Author:  Hanra [ Wed Nov 29, 2006 9:42 pm ]
My Sparco's are a tight fit.... They actually rub on the inside of the door frame. If u can find the dimenions of them, dont go any wider!!!! Sparco Sprints they are, mounted on Cobra frames for Mini.
Author:  Mini Mike [ Wed Nov 29, 2006 9:47 pm ]
Hanra if you get some time tomorrow can you take a quick measurement? Side to side....
Author:  Hanra [ Wed Nov 29, 2006 9:50 pm ]
Yep, if i manage to get out to the shed and unwrap it!! Are u chasing the widest part of the chair? Ill get base width and back width.
Author:  Mini Mike [ Wed Nov 29, 2006 10:05 pm ]
Yeah mate widest part of the base and widest part of the back...... That would be tops mte I appreciate it... I dont have any seats in mine yet so I cant even measure the standard ones..
Mike
Author:  Hanra [ Wed Nov 29, 2006 10:19 pm ]
Dunno if this helps for the time being....?
http://www.jaydm.com/sparco/seats/sprint.htm
Author:  Mini Mike [ Thu Nov 30, 2006 4:43 pm ]
Hanra how did you go mate?
Author:  Hanra [ Thu Nov 30, 2006 5:16 pm ]
I only just finished work....!!!! Were not on daylight saving up here!!!!
Author:  Mini Mike [ Thu Nov 30, 2006 7:51 pm ]
no worries mate when yu get the time
Author:  Hanra [ Thu Nov 30, 2006 9:02 pm ]
Ok, the rear of the chair has like wings around the shoulder area, these rub the door frame, it is 53cm across at that point. The base of the seat, at the front is the widest point, That is also 53cm across. As i said earlier, these chairs sit on Cobra subframes which i had to modify to accept the sparcos.
Author:  Mini Mike [ Thu Nov 30, 2006 11:23 pm ]
thanks heaps hanra your the best mate...
Mike
Author:  bubbos [ Fri Dec 01, 2006 7:05 pm ]
Post subject:  seats
Suzuki swift seats fit well and starlet although they sit close to the hanbrake.
Author:  meeni [ Fri Dec 01, 2006 7:10 pm ]
Hanra wrote:
thats similar to what i have in my race car and it sits against the door frame as you said.. although you could push it in slightly but i dunno what the driving position would be like
Author:  Hanra [ Fri Dec 01, 2006 7:33 pm ]
Yeah its not really a hassle, cause i have the seat so far back, it actually sits just behind the rear of the door frame. If the seat was a little more forward it would rub a lot worse.
Author:  Mini Mike [ Fri Dec 01, 2006 8:33 pm ]
I took some measurements of my mini today and at the cars narowest point inside the cabin I have 116cm where the door catches are... so im thinking the seats im looking at might fit... They say there 56cm at the wides point. So i should have 14cmsto play with..... Maybe.... I hope
