It is currently Thu Aug 21, 2025 3:28 pm
PostPosted: Sat Dec 02, 2006 6:12 pm
Yup I have some brake lines that run through the car. What I need to know are they meant to be there? Originaly I was going to rip them out as the car was a racer and I thought they put them in the car so they dont get ripped out on the track... But I was looking at them closely yesterday and now I think there meant to be there.
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Sat Dec 02, 2006 6:43 pm
Mine certaintly dont go through the car!! They run underneath on the drivers side, fuel line on the passenger side. Then protective cover strip over the top of em.
PostPosted: Sat Dec 02, 2006 6:53 pm
Mike
They did not run through the inside as standard mate, a lot of rally cars and race cars have them inside the cabin :D
Jon
PostPosted: Sat Dec 02, 2006 7:12 pm
Its a 850 if that makes any difference.
PostPosted: Sat Dec 02, 2006 7:16 pm
mike
Sorry mate does not make any difference :D
Jon
PostPosted: Sat Dec 02, 2006 7:19 pm
High heel ninja
Mike, maybe your car has a rally past to it, they run the brake lines, fuel line & batery cables through the car to prevent them being damaged by rocks etc.
Doogie
PostPosted: Sat Dec 02, 2006 7:23 pm
Thats good then.. It means I can start ripping them out.... It has those soft steel tabs that are welded to the floor and they rap around the pipes to hold them in place, thats why I thought it was meant to be there...
PostPosted: Sat Dec 02, 2006 7:32 pm
High heel ninja
Don't be too hasty, it may have works heritage to it.
Doogie
PostPosted: Sat Dec 02, 2006 7:38 pm
huh works heritage????
Im not sure but I dont think saftey was Sue's biggest concern.. The drivers race seat is a high back mini seat with some holes cut into it where your shourders sit, and she had rigged up a few seat belts into a 4 point harness that fed through the holes they cut in the seat.. Anyway anyone recognise the car???
PostPosted: Sat Dec 02, 2006 7:46 pm
di you get Sue from Greenacre by chance
I think I reconise it from a number of years ago when I purchased Cooper S Brakes front role bar and a full role cage
he also had a perfect Cooper S also
I could be wrong thou
PostPosted: Sat Dec 02, 2006 7:49 pm
sure did I got it from Dan about 4 years ago
Users browsing this forum: Bing [Bot], watsupskip and 211 guests
