It is currently Sun Aug 17, 2025 1:36 am
 Post subject: Stupid question
PostPosted: Fri Dec 01, 2006 10:03 am
is there a difference between the thickness of tyres put on 12's and 13's...... and if so does the 12' and 13's end up being the same size in total Diameter ??
"Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac."http://i129.photobucket.com/albums/p218/mini78s/theone.jpg
PostPosted: Fri Dec 01, 2006 10:20 am
the profile will be different...lower for the 13s...(assuming thickness means profile)
but the outside diameter will be nearly the same if not the same...
PostPosted: Fri Dec 01, 2006 10:23 am
whether it's 12" or 13" the thickness depends on the width of the rim again whether it be 5 5.5 6 7" 's wide. with a higher width number you will need to cut and lip/flare the guards etc... plus you may need to adjust various things to get the correct geometry.
PostPosted: Fri Dec 01, 2006 2:05 pm
wooo hoooo im not the only person with stupid questions
PostPosted: Fri Dec 01, 2006 2:21 pm
Steady on - steady on
No such thing as stupid questions - all questions are valid although I have seen stupid answers at times although not necessarily off the Ausmini group.
PostPosted: Fri Dec 01, 2006 2:39 pm
Have a squiz at this - heaps of info and calculators as well.
http://www.carbibles.com/tyre_bible.html
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
