Stupid question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=25469
Author:  MIN.78S aka "higgin [ Fri Dec 01, 2006 10:03 am ]
Post subject:  Stupid question
is there a difference between the thickness of tyres put on 12's and 13's...... and if so does the 12' and 13's end up being the same size in total Diameter ??
Author:  cush [ Fri Dec 01, 2006 10:20 am ]
the profile will be different...lower for the 13s...(assuming thickness means profile)
but the outside diameter will be nearly the same if not the same...
Author:  1360 LS [ Fri Dec 01, 2006 10:23 am ]
whether it's 12" or 13" the thickness depends on the width of the rim again whether it be 5 5.5 6 7" 's wide. with a higher width number you will need to cut and lip/flare the guards etc... plus you may need to adjust various things to get the correct geometry.
Author:  lil-ute [ Fri Dec 01, 2006 2:05 pm ]
wooo hoooo im not the only person with stupid questions
Author:  Mike_Byron [ Fri Dec 01, 2006 2:21 pm ]
Steady on - steady on
No such thing as stupid questions - all questions are valid although I have seen stupid answers at times although not necessarily off the Ausmini group.
Author:  Oscar [ Fri Dec 01, 2006 2:39 pm ]
Have a squiz at this - heaps of info and calculators as well.
http://www.carbibles.com/tyre_bible.html
