It is currently Thu Aug 21, 2025 9:38 am
 Post subject: Clutch disengage
PostPosted: Sat Dec 02, 2006 3:14 pm
The clutch wont disengage.
It has worked after I rebuilt it.
The slave is moving the arm and the arm is returning against the stop when the pedal is released.
I have adjusted the stop to no avail.
Anyone got a procedure for checking.
Thanks
PostPosted: Sat Dec 02, 2006 3:43 pm
Bloke, has it just siezed againts the flywheel? Often with standing they get surface rust and nip up, try shocking it, pump the pedal a few times, then try starting it in gear with the clutch depressed, CAUTION! give yourself some room, and I take it your brakes are all in good working order!! :lol:
Or, it is just not dissengaging, wear on clutch arm ball / spigot, clevis pins and holes etc....
Common problem, put in new clutch arm, inspect for wear etc.
Have you put a new clutch plate in?
Sir Alec! we are not worthy!
PostPosted: Sat Dec 02, 2006 3:46 pm
Or, it is just not dissengaging, wear on clutch arm ball / spigot, clavis pins and holes etc....
Yes, I have put a new clutch plate in, but I have used sucessfully (very limited) since doing so.
I have tried to shock it. maybe I wasnt trying hard enough :lol:
Users browsing this forum: No registered users and 217 guests
