z
https://www.ausmini.com/forums/viewtopic.php?f=2&t=25490
Author:  LordCruiser [ Fri Dec 01, 2006 7:08 pm ]
Post subject:  z
zz
Author:  Morris 1100 [ Fri Dec 01, 2006 7:19 pm ]
Post subject:  Re: Apron, brakes, compression and stuff...
LordCruiser wrote:
2. What's the compression pressure for the 1098? It ain't in my abridged workshop manual.
Compression pressure is a variable. It depends on a lot of things. You can test an engine one day and have a different pressure the next. If you have a bigger overlap cam you will get less pressure on a gauge.
My 1100 has around 125psi in each cylinder. :wink:
Author:  AJ [ Fri Dec 01, 2006 8:18 pm ]
A normal compression would be around 140-150 psi , my 1098 has 175 psi on all cylinders , but it has had some work done to the head . Think pollution motor is lower , around 135 psi
