It is currently Thu Aug 21, 2025 12:21 pm
PostPosted: Thu Nov 30, 2006 7:52 pm
hi, i just got a quick shift and the problem which i'm having is that the quick shift unit will not set all the way down into the rod change unit. it's only a few milameters of but i carn't get it to slid into position. are there any tricks which can heap me install it easyer. the lift pin at the bottom of the quickshifter doesn't seem to be connected to anything. is it meant to be connected to something. i think the rod change unit is australian so could this be the reason.
need help as soon as possible.
thanks
PostPosted: Thu Nov 30, 2006 8:02 pm
its because the australian rod change casting has a slightly wider top then the british ones for which the quickshift is designed.. if you grind a little out of the inside of the bell shaped part of the quickshift it should go on fine
Potato
PostPosted: Thu Nov 30, 2006 8:09 pm
Meeni that is bullshit.
It's bad design on the maufacturers behalf.
Filing around the top of the rod change unit will see the new bit that slips over it fit with a little bit of persuasion from a plastic faced hammer.
Be gentle and don't force it.
im just saying what every person i ever asked told me...
Potato
PostPosted: Thu Nov 30, 2006 9:12 pm
I bought a KAD quickshift for my rod change about 6yrs ago and it fitted perfectly and still works fine now.
PostPosted: Fri Dec 01, 2006 2:45 pm
Them are some strong statements willy - but it seems most stuff meeni says fits the write up. It seems everyone complains about the fit on specificaly the Minispares UK brand of quickshift. I had one a few years back when I still had a rod change and it didnt fit straight away either.
I reckon it'd be much easier to file the inside of the quckshift bell (its made of soft alloy and even sandpaper will take it, than around the (steel I believe) rodchange housing. It shoud fit over the housing tightly but you don't want to bang it too hard, instead remove a bit more thickness from the inside of the bell as if its too tight removing the unit if you decide so in the future would be a nightmare.
PostPosted: Fri Dec 01, 2006 8:20 pm
hi, thanks for your post's but i'm still very confused with what i have to do to make it fit. pictures would help heaps. how much would i have to file off to make the quick shift fit.
if someone could please tell me exactally to grind with pictures showing it would be great.
thanks :D
 Post subject: Quickshift
PostPosted: Sat Dec 02, 2006 7:53 am
Hey volkmini,
As the K.A.D agent in Australia give me (Andrew) a call i can give you the 'tips' to fitting them if you still dont understand, I think most comments have been spot on so far (with regards to fitting quickshifts).
I am at work this morning (saturday) from 8am-12 Adelaide time....
08-8177-1275
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Sat Dec 02, 2006 8:21 am
Dosnt get any easier then that then does it????
PostPosted: Sat Dec 02, 2006 7:23 pm
I purchased the Minisport KAD quickshift a few months ago and fit it to an ausiie LS and all i did was wiggle it side to side as a pushed down on it... No probs at all!
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
Users browsing this forum: Bing [Bot], drmini in aust and 343 guests
