Brake lines through the car? https://www.ausmini.com/forums/viewtopic.php?f=2&t=25509 |
Author: | Mini Mike [ Sat Dec 02, 2006 6:12 pm ] |
Post subject: | Brake lines through the car? |
Yup I have some brake lines that run through the car. What I need to know are they meant to be there? Originaly I was going to rip them out as the car was a racer and I thought they put them in the car so they dont get ripped out on the track... But I was looking at them closely yesterday and now I think there meant to be there. Mike |
Author: | Hanra [ Sat Dec 02, 2006 6:43 pm ] |
Mine certaintly dont go through the car!! They run underneath on the drivers side, fuel line on the passenger side. Then protective cover strip over the top of em. |
Author: | feralsprint [ Sat Dec 02, 2006 6:53 pm ] |
Mike They did not run through the inside as standard mate, a lot of rally cars and race cars have them inside the cabin ![]() Jon |
Author: | Mini Mike [ Sat Dec 02, 2006 7:12 pm ] |
Its a 850 if that makes any difference. |
Author: | feralsprint [ Sat Dec 02, 2006 7:16 pm ] |
mike Sorry mate does not make any difference ![]() Jon |
Author: | doogie [ Sat Dec 02, 2006 7:19 pm ] |
Mike, maybe your car has a rally past to it, they run the brake lines, fuel line & batery cables through the car to prevent them being damaged by rocks etc. Doogie |
Author: | Mini Mike [ Sat Dec 02, 2006 7:23 pm ] |
Thats good then.. It means I can start ripping them out.... It has those soft steel tabs that are welded to the floor and they rap around the pipes to hold them in place, thats why I thought it was meant to be there... |
Author: | doogie [ Sat Dec 02, 2006 7:32 pm ] |
Mini Mike wrote: Thats good then.. It means I can start ripping them out.... It has those soft steel tabs that are welded to the floor and they rap around the pipes to hold them in place, thats why I thought it was meant to be there...
Don't be too hasty, it may have works heritage to it. Doogie |
Author: | Mini Mike [ Sat Dec 02, 2006 7:38 pm ] |
huh works heritage???? ![]() ![]() Im not sure but I dont think saftey was Sue's biggest concern.. The drivers race seat is a high back mini seat with some holes cut into it where your shourders sit, and she had rigged up a few seat belts into a 4 point harness that fed through the holes they cut in the seat.. Anyway anyone recognise the car??? |
Author: | gafmo [ Sat Dec 02, 2006 7:46 pm ] |
di you get Sue from Greenacre by chance I think I reconise it from a number of years ago when I purchased Cooper S Brakes front role bar and a full role cage he also had a perfect Cooper S also I could be wrong thou |
Author: | Mini Mike [ Sat Dec 02, 2006 7:49 pm ] |
sure did I got it from Dan about 4 years ago |
