It is currently Sat Jul 19, 2025 9:40 am
 Post subject: Drive shafts?
PostPosted: Sat Oct 30, 2004 10:47 am
The question was put forward to me last nite over a few drinks, and I couldnt give a definate answer. Is the length of the drive shaft on a disc brake front end different in length to a drum braked front end? Is the CV joint different in any way between the two? Could a drum brake drive shaft and CV be used in a disc brake front end or vice versa? Any ideas!!!!
 Post subject: Re: Drive shafts?
PostPosted: Sat Oct 30, 2004 11:28 am
cvs (outer ) are deffinatey different but the shafts are the same lenbgth ( some had different splines tho )
lookin for another clubby
think the shafts are the same, cv's are definatley different.
1974 Moke - 998cc
PostPosted: Sat Oct 30, 2004 11:38 am
Driveshaft outer splines are all the same, inner splines are same for rubber coupling or `S' Hardy Spicer and so is length,, pot joint splines are different and their shaft lengths are too.
So- pick driveshafts to suit the inner joints you have, and you're sweet, unless it's a hybrid ToyoSuki power unit... :shock:
Only way I know to use discs with Drum CVs is go with Hondas or similar.
Oops, I just tripped over Anton's 9" set... :wink:
PostPosted: Sat Oct 30, 2004 5:05 pm
ok, so could you use pot joint shafts and cv's in a Cooper S disc brake hub??
PostPosted: Sat Oct 30, 2004 6:18 pm
which cvs? cooper S /8.4 ones yes drum cvs no , u can use late pot joint shafts and cooper s /8.4 cvs but drum ones wont fit cooper s disc flanges.
PostPosted: Sat Oct 30, 2004 8:40 pm
Online
Brad, I run pot joints in my sprint mini with S discs & CV's. Steve
PostPosted: Sat Oct 30, 2004 9:02 pm
I'm about to do the same in the S replica-, I'm fitting pot joints and diff shafts to an S box, but the CVs are drum, with Honda brakes.
PostPosted: Sat Oct 30, 2004 10:24 pm
with honda brakes
using the term relpica loosley there aren't you doc ;)
PostPosted: Sat Oct 30, 2004 11:31 pm
Hey if it looks like a duck, sounds like a duck... but yeah it's got Honda brakes- stops better than a duck. And, the wrong hose clamps too... I don't care- my wife likes it, and whatever makes her happy I like too! :lol:
PostPosted: Sun Oct 31, 2004 8:34 am
Morris now has this 8)
PostPosted: Sun Oct 31, 2004 8:38 am
PostPosted: Mon Nov 01, 2004 12:54 pm
ok, so a pot joint shaft could be used but the drum cv cant, so it would need a cv to suit the disc brake hub and also have the same number of splines as the drive shaft, yeah? What Honda model brake setup suits a Mini? Civic?
PostPosted: Mon Nov 01, 2004 3:02 pm
Yeah Honda Civic `83-87. discs are 230mm dia (9"+) but you use with DRUM CVs, drive flanges & swivel hubs, not disc ones. Check out the Honda thread in Mini Mods- I know it's long but just skip the chatter bits. :lol:
With 12x5 wheels, you can leave them at full size and they really stop! For 10x5 wheels you need to turn them down to 7.9".
PostPosted: Mon Nov 01, 2004 3:42 pm
Yeah I spotted that thread bout the brake mod, seems like you have quite a bit of knowledge on that subject Doc. I think I might seriously look into that, along with the N12 dizzy mod. Ill have to go though the entire thread and check it all out. Well I have 12 by 5 superlites, so that will be good leavin em full size diam. Thats great, thanks!!!!
Users browsing this forum: No registered users and 72 guests
