Fluctuating Idle https://www.ausmini.com/forums/viewtopic.php?f=2&t=25758 |
Author: | Razor [ Mon Dec 11, 2006 10:01 pm ] |
Post subject: | Fluctuating Idle |
Hi My engine (1275) twin HS2s has a fluctuating idle from 1200 - 1500 rpm, if you press/blip the throttle the idle goes down a little or slowly idles down to normal or below normal where the engine wants to stall. Checked the throttle cable and its not binding or sticking. My guess is running too rich? there's no black smoke when I rev the car or drive it harder than normal or sluggish etc. Any advice peeps? |
Author: | smurf11 [ Mon Dec 11, 2006 10:12 pm ] |
mine does the same thing. Im not sure why but was thinking maybe a sticky butterfly ![]() I am going to kit mine when i finally get round to starting my restoration |
Author: | AEG163job [ Tue Dec 12, 2006 9:05 am ] |
1200-1500 is pretty high idling for 1&1/4's. How annoying ![]() ![]() ![]() |
Author: | Mike_Byron [ Tue Dec 12, 2006 9:22 am ] |
I agree with all above - in a nutshell its sucking air or gettting to much petrol. Check the manifold alignment for leaks as well as all of above. But........ spindle wear is the most likely major contributor |
Author: | Razor [ Wed Dec 13, 2006 8:49 pm ] |
I've noticed at 1st start from cold my idle will be around 1200rpm runs fine after say 15-20min drive the rpm is sometimes 1500rpm or sometimes around 800rpm if its sitting on 1500rpm if I press/blip the throttle it kinda goes down slowly or sometimes the engine wants to stall on neutral or on gear at full stop |
Author: | Hanra [ Wed Dec 13, 2006 8:54 pm ] |
Buy ya self a can of Clean R Carb, while the engine is running spray it around the manifold where it meets the head, also spray around the throttle shafts. If there is an air leak, the engine revs will rise briefly!!! |
Author: | drmini in aust [ Wed Dec 13, 2006 9:03 pm ] |
As others say, it's a symptom of throttle shaft wear. Barney's twin HS4s do it a bit too, but not bad enough that I'll worry yet. Pity that Mr SU didn't use proper (ball) spindle bearings and seals, a la Weber and Dellorto... ![]() |
Author: | 1018cc [ Thu Dec 14, 2006 10:41 am ] |
I reckon the throttle shafts are worn, that's what happened to me. It stopped once i put my new carbies on (they were rebuilt). |
