It is currently Fri Jul 18, 2025 10:37 pm
PostPosted: Tue Dec 12, 2006 4:51 pm
Hi guys
i just bought this set off twin carbs, and i need to know what screws or plugs etc to use to block the vacume take off point and the pcv (pvc? cant remember) take off on the cooper s manifold.
If anyone can tell me where i can get them, etc, or what thead they are it would be a great help.
Heres a pic to help you see what i mean.
Cheers Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Dec 12, 2006 5:31 pm
The threads are 5/8-18 UNF, they are NOT 3/8 BSP- (which is a pipe thread, is about 1mm bigger and 19TPI).
I take a 3/8 BSP plug, nipple, or whatever you want to screw in there, machine it to 5/8" diameter then recut the thread with a 5/8 UNF dienut.
Sure- there are/were 5/8 UNF plugs and hose nipples for this manifold which were available from BMC, I just find it easier to make my own than go hunting....
PM me if you need some made. :wink:
PostPosted: Wed Dec 13, 2006 8:56 am
I found a (non-mini) sump plug that just screwed straight in. Was only about 1/2" long, so it filled the gap perfectly. Not sure if it was the right thread, it seemed to fit well though.
Not using that manifold now anyway!!
PostPosted: Wed Dec 13, 2006 6:09 pm
I'm making him some brass ones up. :wink:
