bolting ball joint back together?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=25870
Author:  nathanm [ Fri Dec 15, 2006 8:54 pm ]
Post subject:  bolting ball joint back together?
im trying to bolt the back together and i can tighten it to a certain point but then it starts turning round like you have to hold on to something to stop turnig
so my q. is how do u do this
sorry if this doesnt make much sense im new to this
thanks nathan
Author:  Harley [ Fri Dec 15, 2006 8:59 pm ]
Provided both parts are paint, dirt and grease free, they should be fine.
some light taps with a fibre hammer may help settle the joints in a bit.
Put some copper grease on the retainer nut too.
:D
Author:  DOZ [ Fri Dec 15, 2006 9:19 pm ]
Put some weight on it, ie with the jack under the bottom arm.
Daniel
Author:  buztoy [ Fri Dec 15, 2006 10:40 pm ]
what he said, jack from underneth act as your hand, i was told to also add a flat washer with a lock washer,
Author:  Rodney [ Sat Dec 16, 2006 10:21 am ]
Like they said above - put a jack under and carefully pump it up a bit or the other way is to lower the car down with a length of 4 x 2 (or similar) on its end (of course) under the ball joint.
Happy Chrissy
Author:  drmini in aust [ Sat Dec 16, 2006 10:26 am ]
A lock (spring) washer should not be used with a flat washer. It defeats the purpose of the spring washer... as the flat washer can spin it undone. :wink:
Author:  buztoy [ Sat Dec 16, 2006 10:32 am ]
so i allready have so what should i replace it with
Author:  drmini in aust [ Sat Dec 16, 2006 11:36 am ]
A new spring washer... :wink:
The idea of a spring washer is the ends bite in and prevent it unscrewing.
Alternatively, use a Nyloc nut, no washer needed.
Author:  buztoy [ Sat Dec 16, 2006 11:53 am ]
but then it would chew into the rubber or it that ment to happen
