It is currently Fri Jul 18, 2025 1:11 pm
 Post subject: Head ID problem....
PostPosted: Fri Apr 09, 2004 3:27 am
Hey guys!!
I was going thru my boxes of goodies when i found a head i had bought a while back.. There's one problem - it has no ID stamp... Maybe someone on AUSMINI can be of help?? I'm THINKING its a 12g206, but i'm not sure
Here are the features....
It has a few codes casted on top. "18C7" is behind the thermostat housing, "ECAM" and "4004" are left of the 4th rocker post.
The port face is totally flat, with "19 9 01" stamped under the centre valve - so it has obviously been modified...
The inlet ports are round, and taper gradually from 24mm internally to 29.5mm at the face.
Exhaust ports are rectangular.
#1 and #3 ports are 25mm high and 20.5mm wide.
#2 exhaust port is 26mm high and 23.5mm wide.
It has a temp sender. There are also 4 plugs along the spark plug face, 1 next to each spark.....
Someone toldl me it could be a 12g202, but i cant find that code.....
Can anyone identify this head and maybe tell me if these ports are normal / crap??
Much appreciated!
Nathan
PostPosted: Fri Apr 09, 2004 6:37 am
CAM 4004, `smog 998' head.
Nothin' special- basically it's a 12A1456 head, (ie stock 998) with the air injection ports added.
A 12G202 (1098) head is better to modify, as ports are bigger & square inside. 8)
PostPosted: Sat Apr 10, 2004 12:19 am
sounds like it would be best used in a marine application - say.... as an anchor??
PostPosted: Sat Apr 10, 2004 7:10 am
:lol: :wink: :P
Good idea, unless it's all U got... :!:
PostPosted: Sat Apr 10, 2004 1:49 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
or you could setup some ntris direct prot injetion :))
makka
PostPosted: Sat Apr 10, 2004 2:15 pm
Errr, the air injection was into the exhaust ports after the valves... put nitrous in there & it would probably oxy cut the exhaust, do little else... 8)
PostPosted: Sat Apr 10, 2004 5:10 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hmmmmm bugga
makka
