quick question on oil filter change https://www.ausmini.com/forums/viewtopic.php?f=2&t=25998 |
Author: | marcsvenson [ Wed Dec 20, 2006 9:26 pm ] |
Post subject: | quick question on oil filter change |
am i right in thinking i only have to tighten the oil filter by hand and shouldnt tighten using the strap that i used to take it off i know i read it somewhere but cant remember just hand tighten ? thanks in advance |
Author: | Harley [ Wed Dec 20, 2006 9:34 pm ] |
Hand tight. Not as tight as you can manage either, you'll know when it's right. ![]() |
Author: | DOZ [ Wed Dec 20, 2006 9:35 pm ] |
For ryco filter it says to turn 2/3rds of one turn after contact with gasket, this is easily achieved by hand. Just check for leaks after warming engine up Daniel |
Author: | 9YaTaH [ Wed Dec 20, 2006 9:36 pm ] |
Post subject: | Tighter |
I assume a spin-on. Slightly more than hand tight...unless your name is Schwarzenegger. The idea is to bring the rubber gasket up to the mating face and then slightly compress it....say 1/2 to 3/4 of a turn after contact with the filter wrench. The last thing you want is for the filter to unscrew through vibration and dump your oil. |
Author: | marcsvenson [ Wed Dec 20, 2006 9:38 pm ] |
thanks heaps guys i will tighten it a little more tommorow morn |
Author: | Lillee [ Thu Dec 21, 2006 8:25 am ] |
make sure you've oiled the rubber lip otherwise you'll have a hell of a time getting it off |
