Brake squeaking any idea https://www.ausmini.com/forums/viewtopic.php?f=2&t=26009 |
Author: | 8a8y8 [ Thu Dec 21, 2006 10:57 am ] |
Post subject: | Brake squeaking any idea |
i just got a brake booster fitted to the car but it squeaks in the morning when the car is cold is that normal?? i have disc brakes. thansk |
Author: | dove grey 64 [ Thu Dec 21, 2006 11:35 am ] |
the brake booster squeeks or the disk rotors? if its the disk rotors its normal. crystalisation (???) builds up over night.to wear it back to normal i just drive along in 2nd, left foot on the brake until the noise stops. |
Author: | DTrain [ Thu Dec 21, 2006 4:26 pm ] |
when do the brakes squeel? under heavy load or all the time? Brake squeal 1. Worn retaining pins (disc). --->>> Fit new pins. 2. Faulty damping shims or shoe retaining clips. --->>> Fit new shims or clips. 3. Dust in drum. --->>> Remove dust from drums and shoe. 4. Loose backplate or calliper. --->>> Tighten calliper or backplate. |
Author: | Mini Mitch [ Thu Dec 21, 2006 6:56 pm ] |
check your brake booster the factory issued mouse may still be inside. |
