wheel lock removal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=26062
Page 1 of 2
Author:  marcsvenson [ Fri Dec 22, 2006 8:37 pm ]
Post subject:  wheel lock removal
ok i lost my wheel lock socket i have looooked everywhere and will have one last look tommorow - i know im an idiot as i also misplaced the packet with the codes for replacements
would this kit actually worked how do you all get them off surely someone has bought a car with them on and had no socket or suffered the same prob
http://www.sjdiscounttools.com/lt4000.html
Author:  drmini in aust [ Fri Dec 22, 2006 8:47 pm ]
Hammer and cold chisel worked for me.
I was mad too when I lost it.... :x
Then I thought- meh, they're only crappy old Contessas, who would steal em... :lol:
Author:  marcsvenson [ Fri Dec 22, 2006 8:54 pm ]
yeah thanks doc
i actually had the car booked in for matt to do somethings to it brakes etc and got up looked around and swore for about two hours
then called matt :oops:
he suggested chisel
went to the wheel shop and they wernt much help said to use a drill but dont wreck the wheels :roll: yeah thanks
Author:  mad-mk1 [ Fri Dec 22, 2006 8:56 pm ]
hmm whith toold like that out, nothing is safe
:roll:
Author:  DOZ [ Fri Dec 22, 2006 11:11 pm ]
The old trick is the slightly smaller socket (cheapo) and hammer it onto the lock nut. Obviously if yours is an internal (like allen key) this won't work.
Daniel
Author:  drmini in aust [ Sat Dec 23, 2006 5:46 am ]
Most lock nuts for Minis are round with an external keyway, the BFH & chisel undoes `em fine... :wink:
Author:  KLAS [ Sat Dec 23, 2006 7:35 am ]
this was my way last time i had to remove wheel locks without the key
Author:  buztoy [ Sat Dec 23, 2006 8:52 am ]
hey are you trying to remove a contessa wheel lock, i sold my contessas but the bloke didnt take the lock nuts, i have the "unlocker thingy" if you want,
hey doc, hows steve oing with those wheels, are they still too close to the trailing arm or...
Author:  marcsvenson [ Sat Dec 23, 2006 9:10 am ]
so you take a chisel and lign it up in the centre of the nut and smack it hard with a bfh or you pry it off with the chisel
am i trying to spliy the nut in half :?:
Author:  smiling_simon [ Sat Dec 23, 2006 9:22 am ]
Post subject:  lock nuts
You can take it to a bob jane or a tyre place and they will be able to rip it off with an air gun and some secret tool. I did this to for my mate after he lost his key, they charged me about $20 - $40 bucks. You should bring spare nuts because no, you will not be able to re-use the lock nuts!!!
Author:  drmini in aust [ Sat Dec 23, 2006 9:37 am ]
They are fine, no problem.
`Mini offset' Contessas are designed for the flat drums on a deluxe or K... :wink:
Just legal with no flares. 8)
Author:  marcsvenson [ Sat Dec 23, 2006 9:42 am ]
yeah i will try a different bob jane and after xmas as the one i went wasnt much help
Author:  awdmoke [ Sat Dec 23, 2006 10:18 am ]
You can use one of those "universal sockets" that are sometimes sold in crap stores.
Looks kind of like a spark plug socket with lots of little rods inside it,
when you push it over the nut the little rods conform to the shape of the nut.
Sell for under $10, but they don't last very long (the little bits break off)
Author:  gafmo [ Sat Dec 23, 2006 7:47 pm ]
I had exactly the same problem recently with the Alfa 75..Worked a treat :wink:
Author:  Morris 1100 [ Sat Dec 23, 2006 8:07 pm ]
I used to just get a wheelnut and weld it to the lock nut. On the next wheel I would weld the wheel nut and lock nut from the first wheel.
When you finish you have four lock nuts and a wheelnut welded together. 8)
