It is currently Sun Aug 10, 2025 2:58 pm
 Post subject: How many rubbers?
PostPosted: Sun Dec 31, 2006 1:18 pm
While digging the crud out from around the lower wishbone arm I noticed the rubber bushes were breaking up. The parts diagram is a little unclear - is there one or two rubber bushes per side?
David L
PostPosted: Sun Dec 31, 2006 1:40 pm
Two.
Earlier bushes (850 era) are parallel bushes, later bushes are tapered to make them easier to fit.
PostPosted: Sun Dec 31, 2006 2:08 pm
The later tapered bushes come with a steel bush inside them, the early ones don't.
They are not interchangeable with early ones, the hole in lower arm is different.
