What colour is the aux wire PLEASE
https://www.ausmini.com/forums/viewtopic.php?f=2&t=26266
Author:  marcsvenson [ Sat Dec 30, 2006 7:55 pm ]
Post subject:  What colour is the aux wire PLEASE
ok now im frustrated what colour on a 78 mini would the aux or accessory wire be - trying to wire a sterio
it was working but the wire was just jammed between the connector plug 5 points where the ignition is and it came out a bit and then stopped working but when i jiggled worked again so i assume thats why the HU is not comming on
Thanks
Author:  TK [ Sat Dec 30, 2006 8:43 pm ]
just wire the "sterio' to the fuse box.
PS, Marc don't lose my mini spit!
Author:  marcsvenson [ Sat Dec 30, 2006 9:06 pm ]
the one on the inner guard drivers side
but how do you know which wire it goes to i dont have a multi tester
can i run the wire there and just touch the wire on the connections of the fuse boxes and it will power up the HU
PS sorry about the spit TK its all still here set up on it work and life in the way anytime you need it just PM me and i will take it down ready for you
Author:  Hanra [ Sat Dec 30, 2006 10:15 pm ]
Buy a 10 cent circut tester from supercheap, it will light up when u find 12v when the key is turned to ACC.
Author:  marcsvenson [ Sat Dec 30, 2006 10:32 pm ]
working now and i saved myself 10c jk but i was wanted to finish tonight
i will get one though
cheers for the info i ended up running it just back from the fuse
