It is currently Sat Aug 16, 2025 10:50 am
PostPosted: Sun Dec 31, 2006 11:08 am
Okay, I've had enough, I cannot get the crank pulley bolt undone. With two people, a 60cm breaker bar, etc, it just will not budge. And I am turning it the right way, lefty loosey righty tighty! :lol: But seriously, any tips? I don't value the condition of the bolt, I just want it out!
PostPosted: Sun Dec 31, 2006 11:13 am
Anto
I would guess that someone has used locktite on it and it will need some effort to remove, dont be frightened to add a bit of pipe to the breaker bar as leverage is your friend :D or a rattler gun :lol: do you still want that ring compressor, PM me if you do
Jon
PostPosted: Sun Dec 31, 2006 11:16 am
Hi Jon, the only pipe I have in the garage that fits is alloy, which didn't last very long :) I may need to go and get some steel piping from Metalmart or something, I assume they won't be open until Tuesday though.
Don't worry about the ring compressor, I now have two and have managed to assemble the motor without a hickup (well, until now that is). After I convinced the compressor to compress enough for the first piston, it was quite happy to do the other three no dramas :)
PostPosted: Sun Dec 31, 2006 12:31 pm
After I had to get the big nut in the gear box drilled off I found out that a bit of gentil heat will soften locktite - about 250* - good luck
David L
PostPosted: Sun Dec 31, 2006 12:55 pm
If it's in the car, put a socket and bar on it, lean bar against the crossmember and hit the starter... it should jar it loose. :wink:
If out of the car, put a main bearing shell in the ring gear inside the flywheel housing to lock it.
Get a decent bit of pipe on that breaker bar, 1M at least. 8)
If all else fails, it's rattle gun time. :wink:
 Post subject: Lever
PostPosted: Sun Dec 31, 2006 3:22 pm
You are welcome to borrow the arm off my large floor jack...about two metres long and about 30mm ID :twisted:
 Post subject: crank pulley bolt
PostPosted: Sun Dec 31, 2006 4:28 pm
Had the same problem Friday but with the motor out, got the big socket and rattle gun to work. Don't know I haven't employed it before, piece of cake.
PostPosted: Mon Jan 01, 2007 11:32 am
Dead easy with a rattle gun - if you have one or can get a lend.
Rod Image
Users browsing this forum: No registered users and 327 guests
