It is currently Sat Jul 19, 2025 3:39 pm
 Post subject: Name the part
PostPosted: Tue Nov 02, 2004 2:34 pm
This is the part that the dip stick slides in and out of, it's either worn or missing o rings as it pulls straight out with the dipstick, causing a small oil leak as it's not sealing.
What's it called so I can try and get a replacement?
Thanks :roll:
PostPosted: Tue Nov 02, 2004 2:37 pm
its called a "Harry-Potter-Broomstick-Left-Overnight-In-A-Tub-Of-Glue"
Inconspicuously Conspicuous
PostPosted: Tue Nov 02, 2004 2:53 pm
oh, is that what it is- i thought it was called
the round hollow thing that the dip stick goes in... :lol:
serious but, just take the piece with you to a mini
shop and they should know
PostPosted: Tue Nov 02, 2004 4:22 pm
Yeah its missing o rings, I cant remember if there was just 1 or 2, go and see some sort of parts specialist they should have orings and seals. I also used a little bit of araldite around it when I built mine as it was still a little loose. Its still in there after 8000 miles.
PostPosted: Tue Nov 02, 2004 5:39 pm
i'm not sure if the above responses are correct because i'm thinking there's a lonely housewife with an empty drawer right about now... :oops:
PostPosted: Tue Nov 02, 2004 5:40 pm
What you req is a dip stick tube. The one in the photo is an Australian made part and is no longer made. It does not have any o rings fiited to it - it was a "tap in fit" into the block.
English cars used a copper type tube that was not interchangeable.
Hope this helps.
PostPosted: Tue Nov 02, 2004 5:43 pm
looks like some wierd pipe for smoking wacky tabaco :D
1974 Moke - 998cc
PostPosted: Tue Nov 02, 2004 6:07 pm
Clean it and the hole with a rag & thinners, put some Loctite 601 on it, and tap it in there... :wink:
PostPosted: Tue Nov 02, 2004 6:37 pm
The plastic in this thing has minimal fexibility (especialy after al those years) so you want to exercise maximum caution tapping it as it takes nothing at all to make it crumble into pieces. And these are no longer made and nearly impossible to get (I'd like a few if anyone has some) not to mention the inconvenience of shards of plastic in your sump.
PostPosted: Tue Nov 02, 2004 6:55 pm
They are tougher than you think- they are nylon, not those later plastics that fall to bits!
Get an old one- just try to break it... you will be surprised. :wink:
<edit> they don't wear out- I just move 'em from engine to engine... :lol:
PostPosted: Tue Nov 02, 2004 6:59 pm
Doh, looks like I'll just have to find some way of jamming it in there :roll: I'll try good ol loctite though I'm afraid it may be too word for that, would plumpers tape be any good?
PostPosted: Tue Nov 02, 2004 7:08 pm
Yeah it'll seal it- but... don't let it get into the oil...
I'd try Loctite first. If it's real loose I'd use Loctite 515 master gasket, it fills gaps better.. :wink:
PostPosted: Tue Nov 02, 2004 7:17 pm
Loctite 515 it is, thanks :D
 Post subject: dipstick tube
PostPosted: Wed Nov 03, 2004 5:32 am
I had the same problem with my dipstick tube 2 years ago were the tube would come out with dipstick.
I wrapped some plumbers tape around the top of the tube and pushed back into the block, its been good ever since
PostPosted: Wed Nov 03, 2004 10:51 am
You sir are a clown.....but a funny clown nonetheless :lol:
[Maverick] 1971 Mini K
