Reluctant Crank Pulley Bolt https://www.ausmini.com/forums/viewtopic.php?f=2&t=26283 |
Author: | Anto [ Sun Dec 31, 2006 11:08 am ] |
Post subject: | Reluctant Crank Pulley Bolt |
Okay, I've had enough, I cannot get the crank pulley bolt undone. With two people, a 60cm breaker bar, etc, it just will not budge. And I am turning it the right way, lefty loosey righty tighty! ![]() |
Author: | feralsprint [ Sun Dec 31, 2006 11:13 am ] |
Anto I would guess that someone has used locktite on it and it will need some effort to remove, dont be frightened to add a bit of pipe to the breaker bar as leverage is your friend ![]() ![]() Jon |
Author: | Anto [ Sun Dec 31, 2006 11:16 am ] |
Hi Jon, the only pipe I have in the garage that fits is alloy, which didn't last very long ![]() Don't worry about the ring compressor, I now have two and have managed to assemble the motor without a hickup (well, until now that is). After I convinced the compressor to compress enough for the first piston, it was quite happy to do the other three no dramas ![]() |
Author: | Wombat [ Sun Dec 31, 2006 12:31 pm ] |
After I had to get the big nut in the gear box drilled off I found out that a bit of gentil heat will soften locktite - about 250* - good luck |
Author: | drmini in aust [ Sun Dec 31, 2006 12:55 pm ] |
If it's in the car, put a socket and bar on it, lean bar against the crossmember and hit the starter... it should jar it loose. ![]() If out of the car, put a main bearing shell in the ring gear inside the flywheel housing to lock it. Get a decent bit of pipe on that breaker bar, 1M at least. ![]() If all else fails, it's rattle gun time. ![]() |
Author: | 9YaTaH [ Sun Dec 31, 2006 3:22 pm ] |
Post subject: | Lever |
You are welcome to borrow the arm off my large floor jack...about two metres long and about 30mm ID ![]() |
Author: | 64cooper [ Sun Dec 31, 2006 4:28 pm ] |
Post subject: | crank pulley bolt |
Had the same problem Friday but with the motor out, got the big socket and rattle gun to work. Don't know I haven't employed it before, piece of cake. |
Author: | Rodney [ Mon Jan 01, 2007 11:32 am ] |
Dead easy with a rattle gun - if you have one or can get a lend. Cheers |
