slinkey inc wrote:
Justin, your a smart bloke. a budget of $4500 will get you a good, decent, driveable mini. Some things to look for that make one car worth more than another is motor size (eg a 1275cc is generallly worth more than 998cc) but if you do get 1275 mak sure it's got front disc brakes, which is also a good thing to have. Roundnoses (60s models and some really early 70s) are usually more desireable than a clubman (like the one in the photo, hey are a 70s model. Ausmini is a wealth of mini info, just ask questions and you'll more than likely get a good, honest answer.
<edit> that LS add claimed that the mini has 'power steering', i hav never ehard of or seen a mini with power steering, they don't need it. That is still false advertising though.
You should post an add in the 'wanted' section.
Sure is the law here too. What I emant was, if 1275 needs disc brakes, if it is small bore (850, 998, 1100) doesn't need them but is a good thing to have, I personally would go discs on every mini I have, both minis I have are 1275's and both need discs so they have them anyways.
1977 Leyland Mini LS - Project LS-T
