Metro Brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=26406 |
Author: | miniboy1962 [ Thu Jan 04, 2007 11:51 am ] |
Post subject: | Metro Brakes |
I keep hearing about the Metro Turbo Brake Setup, apparently it needs some modifications to fit the mini. Just got a couple of questions. 1. What modifications are needed to fit it to my mini. 2. Is this option a relatively cheap brake solution? 3. How is the brake performance compared to other setups? |
Author: | TheMiniMan [ Thu Jan 04, 2007 12:22 pm ] |
(1)--> The ball joints need to be Mk1 metro, & duel brake hose mods to suit the single on the mini.. (2)---> yes relatively cheap concidering their performance compared to other disc brakes, but 12 or 13" wheels will need to be fitted so that often cancells out much of the "cheapness" (3)---> Yes , much better braking ability/performance,,, but the added weight detracts from the suspension response & over all recipricating weight affecting accelleration. & you`d probably want to fit a full set of adjustable control arms to get the wheel alignment sorted. My thoughts---> Too big,,, Too heavy,,, Too much mucking around,,, Too much money & time to bother,,, i`d rather just stick some cooper "S" discs on with quallity pads & keep it on 10 inch wheels,,, but that`s just me. would be ok if you had a rocket ship turbo or supercharged set up with big grunt & needed the extra stopping power & the big foot print (tyres) for the grip factor, but the suspension suffers with all that weight. |
Author: | cush [ Thu Jan 04, 2007 12:42 pm ] |
TheMiniMan wrote: i`d rather just stick some cooper "S" discs on with quallity pads & keep it on 10 inch wheels,,, but that`s just me.
*hugs matt* |
Author: | Harley [ Thu Jan 04, 2007 1:57 pm ] |
TheMiniMan wrote: ......the suspension suffers with all that weight.
I've just been in the garage with some scales. ![]() There's not much difference actually. Maybe a poofteenth of a kilo tops. The assembled metro caliper (that's pistons, seals and pads) is 300 grams lighter than the stock 8.4 caliper in the same state of assembly. The metro rotor however, weighs 300 grams more. Drive flanges are very similar to each other as well. ![]() |
Author: | cush [ Thu Jan 04, 2007 2:08 pm ] |
Harley wrote: TheMiniMan wrote: ......the suspension suffers with all that weight. I've just been in the garage with some scales. ![]() There's not much difference actually. Maybe a poofteenth of a kilo tops. The assembled metro caliper (that's pistons, seals and pads) is 300 grams lighter than the stock 8.4 caliper in the same state of assembly. The metro rotor however, weighs 300 grams more. Drive flanges are very similar to each other as well. ![]() all that x2 + wheels x4 ![]() |
Author: | miniboy1962 [ Thu Jan 04, 2007 3:39 pm ] |
Thanks guys for the quick response. I'm doing a turbo suzuki conversion on 13's so i wanted some pretty good (and cheap) stopping power. So basically i use everything metro? hubs, flanges, calipers, bearings, rotors and then make some sort of joiner hose for the dual brake mod. Is there anything mini in there? I heard there was an issue using all metro when it came to steering geometry? |
Author: | awdmoke [ Thu Jan 04, 2007 5:03 pm ] |
TheMiniMan wrote: & you`d probably want to fit a full set of adjustable control arms to get the wheel alignment sorted.
You will definately need these to correct the geometry, but they are not that expensive. |
Author: | Harley [ Thu Jan 04, 2007 5:22 pm ] |
miniboy1962 wrote: Thanks guys for the quick response. I'm doing a turbo suzuki conversion on 13's so i wanted some pretty good (and cheap) stopping power. So basically i use everything metro? hubs, flanges, calipers, bearings, rotors and then make some sort of joiner hose for the dual brake mod. Is there anything mini in there? I heard there was an issue using all metro when it came to steering geometry?
If you can get your mits on a pair of mini disc hubs, use them. Then steering and suspension geometry correction parts won't be needed. You will also use mini CVs and driveshafts (well, maybe not exactly in your application!) Get tapered roller bearings too. ![]() |
Author: | miniimports [ Thu Jan 04, 2007 8:33 pm ] |
Post subject: | re metro turbo brakes |
if interested in a set we are clearing out some cheap ones for rebuilding,look on ebay under mini metro brakes cheers |
Author: | miniboy1962 [ Fri Jan 05, 2007 9:44 am ] |
So I use... Hubs - Mini Disc or Metro, If Metro i need to get adjustable suspension(control arms) Flanges - Mini or Metro Rotors - Metro Calipers - Metro Bearings - Mini or Metro, depending on which hub i use? or are they all the same And i need to make up dual hose connection for the metro calipers. Is there anything else i need? |
Author: | miniboy1962 [ Fri Jan 05, 2007 9:46 am ] |
Oh also, does it matter what disc hub i use? Is there any difference between the hubs on the 8.4's and the 7's. What size brakes were on the 90's minis? |
Author: | Mokesta [ Fri Jan 05, 2007 10:23 am ] |
The flanges you use depends if you use vented or non vented discs. The vented disc flanges will give you 1/2 inch extra track widthe per side. M |
Author: | miniboy1962 [ Fri Jan 05, 2007 10:36 am ] |
Is it possible to use the non vented flange with a vented rotor to keep the track width as small as possible. Is the non vented flange strong enough? I wouldn't see why not, as long as the shaft thickness is the same. |
Author: | Harley [ Fri Jan 05, 2007 10:49 am ] |
A vented disc is wider than a solid one by almost a 1/2 inch. Use the metro drive flange, as the mounting bolts are a different size. You may also want to get the castelated locator machined off it too. ![]() |
