Extra Cooling https://www.ausmini.com/forums/viewtopic.php?f=2&t=26419 |
Page 1 of 2 |
Author: | Wombat [ Thu Jan 04, 2007 4:19 pm ] |
Post subject: | Extra Cooling |
I've read of using the heater to help cooling and the extension of that using a heater matrix behind the grill. Would an oil cooler matrix plumbed into the cooling system also work? or would you be better off cooling the oil instead? |
Author: | Lillee [ Thu Jan 04, 2007 4:31 pm ] |
hmm just use a matic under bonnet heater. easy to install and plumb in and 1) it adds quite a lot of water to the system 2) cools the water if the heater is on or off 3) Is really warm in winter ![]() |
Author: | Mick 77 [ Thu Jan 04, 2007 5:24 pm ] |
I have been toying with the idea of a similar return plumb back cooling system. Something like using a pressurised system with a Range Rover filler tank feeding into the radiator then return of water from the heater outlet through a front mounted heater core plumbed back into the radiator. I have seen a similar set up on a couple of nice blue roundies from Warwick while at the Leyburn sprints but without the additional heater core. Appreciate any feedback/ responses if someone has done something similar. |
Author: | Wombat [ Thu Jan 04, 2007 5:38 pm ] |
What made me think about it was KC in Mini Experience says that by keeping the heater on it lowers the temperature at the back end of the block by 15-20* Now leaving the heater on in the UK may be OK but not sunny Queensland ![]() |
Author: | gafmo [ Thu Jan 04, 2007 5:43 pm ] |
Leave the heater on is easy...just a matter of takeing out the matrix's from a clubby heater and sticking it behind the front grill with the same piping...just works the same way but more fresh air ![]() |
Author: | drmini in aust [ Thu Jan 04, 2007 6:26 pm ] |
Wombat wrote: What made me think about it was KC in Mini Experience says that by keeping the heater on it lowers the temperature at the back end of the block by 15-20* Now leaving the heater on in the UK may be OK but not sunny Queensland
![]() If you use a matic heater (also was optional on Deluxe and K) it's under bonnet, with heater off the air is diverted into the engine bay so the engine still gets cooled. It's an air mixing heater- water flows all the time, but you control the air into cabin, none-cold-warm-hot. |
Author: | Wombat [ Thu Jan 04, 2007 6:40 pm ] |
OK anyone got one for sale ? ![]() |
Author: | drmini in aust [ Thu Jan 04, 2007 6:44 pm ] |
Wombat wrote: OK anyone got one for sale ?
![]() I do, if Brad still has it... must ring him. I'll let you know. $50 is the going rate, + post. ![]() |
Author: | Wombat [ Thu Jan 04, 2007 6:45 pm ] |
I'll take it if available |
Author: | 13secmini [ Thu Jan 04, 2007 7:11 pm ] |
yep stll got it here kev ![]() |
Author: | drmini in aust [ Thu Jan 04, 2007 7:14 pm ] |
Thanks Brad. OK Wombat it's yours, I'll box it up and weigh it, let you know the postage. ![]() |
Author: | Lillee [ Thu Jan 04, 2007 8:18 pm ] |
One happy customer! Wombat, do you have a brake booster? cause if you do, it won't fit! |
Author: | Wombat [ Thu Jan 04, 2007 8:44 pm ] |
Bug*er |
Author: | drmini in aust [ Thu Jan 04, 2007 9:43 pm ] |
Under the dash with it then, like the works cars... ![]() |
Author: | slinkey inc [ Thu Jan 04, 2007 10:23 pm ] |
I got myself a "i dont know what this car this came from so you can buy it cheap" heater core. It was in perfect condition, and looks jsut like an 1100 core but twice as long. That is going up-front IF this 2-care 'hi-flow' thing that came from Karcraft isn't good enough, but I think it will be. But hey why not have the extra cooling? Just give you assurance that a min can run in 40 degree heat, atm mine can't, even with a thermo fan. |
