Another wiper question https://www.ausmini.com/forums/viewtopic.php?f=2&t=26474 |
Author: | Wombat [ Sat Jan 06, 2007 11:44 am ] |
Post subject: | Another wiper question |
With the motor off should you be able to operate the wipers by hand by pushing and pulling the cable thingy? I'm looking for a reason why the wiper armature cooked itself and although the grease in it was thick I don't think it was solid enough to sieze the works. The wipers however will not move by hand. |
Author: | drmini in aust [ Sat Jan 06, 2007 1:05 pm ] |
If you disconnect the motor/box assembly from the cable, then yes, you can move it to and for by hand. You won't move it with it all bolted up. Too much gear reduction (including a worm drive) in the system. |
Author: | Wombat [ Sat Jan 06, 2007 1:16 pm ] |
The motor is off the cable (and in pieces on my workbench) - I'm trying to push the cable back and forth and make the wipers move |
Author: | drmini in aust [ Sat Jan 06, 2007 1:17 pm ] |
It's seized then. Take the wheelboxes apart. grease is good... ![]() |
