where is the best place to buy needles.... and how can we decide which needle is best for our engine.... ( using vizards book?)
Hi Tait
The best place to buy SU needles is from Midel (in Sydney) whop are the australian agents for SU. You are best off buying a reco kit as well as new jets when you buy the needles.
As for what needles - thats a difficult one because so many factors affect the needle choice. Given all the engine data we can make educated guess, use WinSu or John from Midel can advise but ultimately the only way to know is to check the burn characteristics using a dyno or something like colortune.
However, having all of tail covering stuff - if YOU use needles that work in a 998 Cooper then you are not goingto be too far out. Graham could tell you whats in one of his cars.
BTW - how is the mini going. - I saw a reference you made in a post about rebuilding your motor.
