1/4 vent window replacement https://www.ausmini.com/forums/viewtopic.php?f=2&t=26603 |
Author: | mikey_ok [ Wed Jan 10, 2007 1:24 am ] |
Post subject: | 1/4 vent window replacement |
I've been advised that replacing 1/4 vemt window rubbers with new rubbers is a waste of time - cause they just pull out of their channel the first time you close them... ![]() Does anybody have any tips on how to make the rubbers stay put?? - mike. |
Author: | mikey_ok [ Wed Jan 10, 2007 1:39 am ] |
For a round nose that is... - m. |
Author: | AEG163job [ Wed Jan 10, 2007 7:26 am ] |
yes, like all rubbers, a PITA. I will be using silastic to fix mine next time round,( in the bottom channel which should also help waterproofing). I think the trick is to adjust the nuts correctly on the quarter vent spindle so that they are not too tight and the 1/4 vent frame does not bind on the bottom rubber. From memory, the drama arises when the assembly is put back in the door-seems to work fine out of the door! Maybe its a problem with the reproduced seals, not manufactured to the correct specs as per the original SARM ones. |
Author: | Hanra [ Wed Jan 10, 2007 8:29 am ] |
Yeah, i replaced my quarter vent rubbers, and your right they do try n pull them selves out of the frame. But with the placement of my bullet rear view mirrors, I cant open them anyways..... |
