which honda brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=26611 |
Page 1 of 2 |
Author: | thedog74 [ Wed Jan 10, 2007 11:26 am ] |
Post subject: | which honda brakes |
what year model civic brakes can fit on a mini going to the wreckers to get some getting 12' rims next week |
Author: | harvey69 [ Wed Jan 10, 2007 11:28 am ] |
http://www.ausmini.com/forums/viewtopic.php?t=16907&postdays=0&postorder=asc&highlight=camira&start=15 |
Author: | thedog74 [ Wed Jan 10, 2007 12:16 pm ] |
thanks dude, Surprisingly I read that thread yesterday and didnt see the year model. too busy dreaming about my mini I suppose. |
Author: | harvey69 [ Wed Jan 10, 2007 12:24 pm ] |
yer....lol... i have been looking into the conversion alot lately.... thats how i remembered the thread... good luck .... would love to see progress when you put them on.... |
Author: | Hanra [ Wed Jan 10, 2007 12:40 pm ] |
B careful as to wat 12in wheels u get! My performance superlites will not fit over the honda discs without machining down of the rotor. |
Author: | drmini in aust [ Wed Jan 10, 2007 1:02 pm ] |
Hanra wrote: B careful as to wat 12in wheels u get! My performance superlites will not fit over the honda discs without machining down of the rotor.
OTOH, Mini Mad's Performance 12x5 Superlights bolted straight on, with full size 9.1" Honda rotors, don't even need any spacers. Apparently Superlites are not all the same, check `em... ![]() |
Author: | Hanra [ Wed Jan 10, 2007 3:47 pm ] |
Yeah, my superlites are stepped on the inside of the rim. If i wanted to fit the honda kit, id need to make it to suit 10 inch rims. Cause the inside of my rim is basically the same as a 10 inch rim...... |
Author: | thedog74 [ Wed Jan 10, 2007 4:40 pm ] |
I'm about to buy some from Tempe Tyres (12" rims). I have no idea if they will fit. Am I better off getting the 12" or 13" rims or are the 13" rims opening up a whole new set off problems. |
Author: | drmini in aust [ Wed Jan 10, 2007 6:12 pm ] |
Both will fit. Anton had Tempe Tyres' 12s on JAM with std Honda Civic brakes. |
Author: | thedog74 [ Wed Jan 10, 2007 8:13 pm ] |
thanks, cant wait to get them now. Any tips on getting them installed. I'd prefer a brake place to do it, as I havent got a clue and dont want to muck around with brakes. Any place you could recommend me to, I'm in the "Hills" as well. |
Author: | Monster Mini [ Wed Jan 10, 2007 8:22 pm ] |
I just got my 8.4s put in last week from Classic Mini Spares Ermington around $200 bucks...Real happy with them... ![]() Cheers Monster Mini ![]() ![]() ![]() |
Author: | gafmo [ Wed Jan 10, 2007 8:58 pm ] |
Another one in the Hills ![]() ![]() yep pop into Classic Mini Spares Ermington Craig will fix you up |
Author: | thedog74 [ Mon Jan 22, 2007 8:23 am ] |
I've got the calipers and disks, what else would one need. Has anyone in oz got a mounting plate for the calipers. I've got my 12" rims now so I'm looking forward to slapping the brakes on. |
Author: | Dave Elliott [ Mon Jan 22, 2007 3:25 pm ] |
Hi, I've done three 9.1" Honda conversions now, with mixed results. I have been getting my rotors and calipers from a local (Perth) wrecker, problem is that they have all been "off the shelf" so I can't be certain of age or model. I have been told that most of the 9.1" rotors are off jap imports (i.e. front-cuts) of late 80"s Civics. Whilst searching at the wreckers I did find a pair of smaller Civic discs (~8.4"), unfortunately there wer no calipers. I think they were off a 70s model...probably very rare now. All 12" rims I have tried require a spacer (minimum 15mm) to clear the caliper when doing the 9.1" conversion. Having said that, I have managed to fit a set of Performance Hotwires without spacers by grinding a bit off the calipers...not too much. It also helps if the pads are not brand new. I have an AutoCad drawing of the bracket, PM me if you want a copy. Chers, Dave |
Author: | willy [ Mon Jan 22, 2007 6:43 pm ] |
I am a fan of direct bolt-on jobs. Like FACTORY 7.5s/8.4s ![]() |
