feeding the wiring loom through the door channel?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=26617
Author:  dale 62 [ Wed Jan 10, 2007 2:02 pm ]
Post subject:  feeding the wiring loom through the door channel?
what is the easiest way and what can i use to feed it through?
Author:  Mike_Byron [ Wed Jan 10, 2007 2:30 pm ]
I dont clearly know but short of taping (or superglueing) a bit of string to a mouse's tail and pointing the mouse in the right direction, you could get a couple of very strong magnets. Drill a hole on one and tie a length of string to it.
The use the magnets to drag the string through. Once you have some string to grasp at the right end then tie (or tape) the other end to the loom and drag it through.
I dont know how a tradesman would do it though.
Author:  sports850 [ Wed Jan 10, 2007 2:36 pm ]
Not sure about there but I know getting wires through underground conduits the easiest way was to get a tiny drinks umbrella from somewhere and tape string to it's handle , put it in the conduit and blow compressed air up the conduit . Catching the string at the other end of the door channel could be a problem though .
Author:  VicMini13 [ Wed Jan 10, 2007 3:50 pm ]
When I use to do cable instalations years ago I had a set of "Snakes". These were a tightly wound springs, only a few millimetres diameter but several metres long, that you could feed through walls etc.
Try pushing an old speedo cable inner, or speedo/throttle/choke/bonnet release outer through, then tape the cable to the end and pull it back.
Author:  doogie [ Wed Jan 10, 2007 6:37 pm ]
Get a centre out of a old speedo cable, strong & very flaxable, feed it up 1st, tape the harness to the end & slowly pull it up the a pillar, easiest way to do it.
Doogie
Author:  dale 62 [ Wed Jan 10, 2007 8:18 pm ]
i ended up feeding it through the channel where the hoodlining covers and fed it down neat the front windscreen channel is this all right???
Author:  Mike_Byron [ Wed Jan 10, 2007 8:49 pm ]
Yes exactly right and it comes out in the passenger footwell
Author:  dale 62 [ Wed Jan 10, 2007 8:57 pm ]
i realised this after about 2 hours of stuffing around with it in 40 degree heat :roll:
