Front hub bearing seals
https://www.ausmini.com/forums/viewtopic.php?f=2&t=2665
Author:  J_A_M [ Fri Nov 05, 2004 9:22 am ]
Post subject:  Front hub bearing seals
My book(s) say to fit the bearing seals "with the lip facing towards the bearing"
:roll: Real helpfull that is.....
Looking at the seal, there is a groove on one side, with a spring type retaining ring in it. Does this side face the bearing? That is my interpretation of the above quote from the book.
Author:  gafmo [ Fri Nov 05, 2004 9:35 am ]
Yes
Author:  J_A_M [ Fri Nov 05, 2004 9:39 am ]
:D sweet! thanks Jimbo.
Author:  Chris [ Fri Nov 05, 2004 9:45 am ]
Post subject:  Re: Front hub bearing seals
Yes. Make sure you lubricate the seal running surface with a bit of oil or gresse so the seal does not get damaged.
Author:  J_A_M [ Fri Nov 05, 2004 10:18 am ]
Cool, thanks. Will do!
Author:  13secmini [ Fri Nov 05, 2004 11:21 am ]
just did my bearings yesterday, yes spring towards the inside, car rolls nice and quite now :D
Author:  Lillee [ Fri Nov 05, 2004 11:35 am ]
Fill it up grease before you do that :wink:
Author:  gafmo [ Fri Nov 05, 2004 11:54 am ]
Love the sound it makes when you have just packed the Hub full of grease. You push it on, take it off... :roll: :oops:
Author:  PhildoD [ Sun Nov 07, 2004 8:37 am ]
LMFAO. Yeah, fill the seal with grease as well. Obviously only pack your wheel bearings as required, but if there's any other room, I reckon fill it with grease. Less space for crud to get in then.
