It is currently Sat Jul 19, 2025 3:39 am
 Post subject: Here we go again...
PostPosted: Mon Nov 15, 2004 9:28 am
OK, so I finally got around to taking out my new non working speedo cable to determine why my speedo still isn't working.
In the process, I found out I originally had a speedo cable from an 850 (it's really short), but the new one is longer. I managed to get the cable out without moving anything as well.
I screwed the new cable into the speedo and stuck the other end in a cordless drill and got nothing registering on the speedo.
Do I need an entirely new speedo?
 Post subject: Re: Here we go again...
PostPosted: Mon Nov 15, 2004 9:47 am
Is the end of the inner going into the drive at the back of the speedo? A speedo is nothing more than a rotating plate driven by the cable which is magnetised and a second plate driven by the magnet across an air gap. I have seen the odometer fail to work but usually the speedo needle still does. You were driving it in the correct direction?
Chris
Everything I like is either
PostPosted: Mon Nov 15, 2004 9:49 am
Drills ususally turn in an anti-clockwise direction ... Speedos are clock wise.....
Try reversing the drill ........
Failing that CAll Bill at Olympic instruments at Pymble, NSW ....
J
PostPosted: Mon Nov 15, 2004 11:47 am
Clockwise is usual for drilling and inserting screws.
I've known for speedos not to work until they get to a certain speed, like 40 or fifty. does the drill go quick enough to simulate that?
PostPosted: Mon Nov 15, 2004 1:05 pm
I tried the drill both ways.
I suppose its possible it wasn't spinning fast enough. Anyone know how fast it actually needs to spin?
Users browsing this forum: No registered users and 114 guests
