Anyone know about wheelboxes? https://www.ausmini.com/forums/viewtopic.php?f=2&t=26683 |
Author: | Wombat [ Fri Jan 12, 2007 7:37 am ] |
Post subject: | Anyone know about wheelboxes? |
Can anyone tell me if the wheelboxes from a MKI and all the rest are PHYSICALLY the same diamensions excluding the gear? I know the gears have different number of teeth and the thread is different but apart from that is there any reason why you couldnt change the gears out of a MKI wheelbox into a newer one and use it? |
Author: | drmini in aust [ Fri Jan 12, 2007 3:12 pm ] |
Don't believe the UK people that say the threads are different. Out here the threads are all the same, they are a fine UNF thread. You can screw an Oz 8 side or a 6 side nut onto them. I use the 6 siders, they are much easier to get off as they don't go oval with a bit of spanner pressure. re the other wheelbox differences, I'm not sure- I have 2 sets of Clubby ones assembled on the shelf but the only Mk1s are on Barney. |
Author: | Wombat [ Fri Jan 12, 2007 6:40 pm ] |
WIPER WHEEL BOX 8 SIDED CHROME METRIC MK3 ON Description 8 sided nut for the Mk3 wiper wheel box (37H7200) Mk1 were 6 sided and a different thread Apparently they have a metric thread MSC say that the MKI wheel box had 22 teeth and later ones had 32. Just counted my MKI version and it has 32 teeth - the shaft length is 5mm shorter than the later one. Anyone have a MKI wheel box they can check the tooth count for me - cause if it is 32 then I may as well buy the later version as a replacement - 5mm shouldn't make too much difference. |
Author: | drmini in aust [ Fri Jan 12, 2007 7:57 pm ] |
Wombat wrote: WIPER WHEEL BOX 8 SIDED CHROME METRIC MK3 ON
Description 8 sided nut for the Mk3 wiper wheel box (37H7200) Mk1 were 6 sided and a different thread Apparently they have a metric thread That's the UK one, maybe is, over there. Ours Mk2 on are a different wheelbox, so watch it.. I put 6 side ones on my 70 model Oz wheelboxes, thread looks same, no problem. |
