brake pipe flairing kit
https://www.ausmini.com/forums/viewtopic.php?f=2&t=26700
Author:  Blokeinamoke [ Fri Jan 12, 2007 2:41 pm ]
Post subject:  brake pipe flairing kit
Dnybody had any success with the diy kits.
I have had several pipes made up with various success. All the pipes for the brakes I got made up are perfect, but the last couple for the cluch master to the hose have all leaked badly so I am seeing if DIY would be a better approach.
Author:  drmini in aust [ Fri Jan 12, 2007 2:55 pm ]
Most of the DIY ones now made in Taiwan or China are rubbish, as far as brake work using bundy tube is concerned.
They do a sort-of passable job with copper, but copper brake pipes are illegal here.
Author:  Wombat [ Fri Jan 12, 2007 5:28 pm ]
I'll let you know - just bought a cheap one off flea bay :roll:
Does the tool put the bead type nipple on the end of the tube or is that a separate fitting the double flared pipe butts up to?
Author:  blumin [ Sat Jan 13, 2007 1:17 pm ]
Post subject:  Brake flare kits
KC Tools make a reasonable kit for diy, the ProAm kit
I remade all the pipes for the clubby & did not have one leak, but used all new nuts,
expensive but well worth the effort.
Blue
