manifold database https://www.ausmini.com/forums/viewtopic.php?f=2&t=26717 |
Page 1 of 3 |
Author: | sports850 [ Sat Jan 13, 2007 8:01 am ] |
Post subject: | manifold database |
Since there are so often people asking about different manifolds (weber and SU) I thought we might start a database with pictures of various manifolds . I have a couple of weber manifolds (gooseneck and mid length) and various twin SU manifolds that I'll take pics of later and post , who else can provide pics ? Ideally pics of the manifold by itself or with carb but especially side on in the case of the weber manifolds for easier reference . Pic's of them in the car can be a little difficult to figure out at times ... |
Author: | benjamin [ Sat Jan 13, 2007 8:10 am ] |
metro turbo manifold (flanges have been milled to 8mm on this one , they are usually 12mm and water conections were cut off). To suit a hif44 turbo carburetor but any hs4 or hs6 or hif38 will fit. There are a water cooler manifold as std , probly not very good for n/a for but work great with boosted aplications. the second picture show the complete metro turbo carburetor setup althought blow off valve non std and plenium has been modifyed for intercooler. ![]() ![]() |
Author: | drmini in aust [ Sat Jan 13, 2007 8:16 am ] |
I've got pics of Russell Engineering Weber one- Redline 3005, after some porting- |
Author: | gafmo [ Sat Jan 13, 2007 9:11 am ] |
D.P.E Manifold to Suit a HIF44 Presently on a modified 1100 Don't know much about it realy...but much better than the Log I had before ![]() |
Author: | supercharged 850 [ Sat Jan 13, 2007 1:40 pm ] |
These are factory cast manifolds. The first one is a 1.5" SU standard cast manifold but has had the exhaust part removed with an angle grinder to allow fitment of extractors. ![]() The second one is an MG Metro factory cast manifold to suit a 1.75" SU carb. The exhaust pipes can be cut off to allow fitment of extractors, although the factory ones do flow fairly well, and you can have LCB style pipes made to fit. A 1.5" SU carb can be used on this manifold too. ![]() For split webers, you may want these.... 'R. Longman & Co.' cast alloy manifolds. They are 2 seperate pieces. FIrewall needs a large box section fabricated to allow fitment of the complete assembly. ![]() ![]() ![]() ![]() |
Author: | sports850 [ Sat Jan 13, 2007 1:55 pm ] |
This is my 5th attempt , the forums don't like too many carb sizes etc in a post as it stuffs the system and refuses to post ..... <EDIT> No , it wasn't saying the various carb sizes , it was whenever I typed the name of the company who made the gooseneck weber manifold and the twin 1 1/2 manifold at the bottom of the post in the post it would come up with error messages and refuse to post ..... Frustration plus . Gooseneck for weber ![]() ![]() Warnerford 4 inch for weber ![]() ![]() BMC twin 1 1/4 ![]() Hi Torque twin 1 1/4 ![]() ![]() Unknown twin 1 1/4 , only casting marks are the firing order ![]() ![]() Unbranded twin 1 1/4 on the sports850 ![]() Tiny twin 1 1/8 Alexander ![]() ![]() Twin 1 1/2 made to fit two standard carbs , not a left and right pair . ![]() |
Author: | drmini in aust [ Sat Jan 13, 2007 4:16 pm ] |
Note that Warneford `4 inch' one is identical to a Redline 3005- Redline bought the patterns or the company, not sure which. |
Author: | sports850 [ Sat Jan 13, 2007 4:21 pm ] |
I thought it was the one that was the same , I'll get it off and take the weber off for a better photo when I get the chance . |
Author: | Anto [ Sat Jan 13, 2007 5:20 pm ] |
Twin SU manifold by Lynx, shown here set up for twin HS2s, but can also take twin HS4s or HS6s if you change the studs & enlarge the ports. ![]() |
Author: | Anto [ Sat Jan 13, 2007 5:24 pm ] |
Oh and I also had mega trouble with it refusing to post, so it's something to do with L ynx then??! |
Author: | sports850 [ Sat Jan 13, 2007 5:28 pm ] |
Yes , same drama's as I had , I can't use that word with a capital L for some reason , the forum thinks I'm giving it an instruction to do something that it's not allowed to do .... |
Author: | adeee [ Sat Jan 13, 2007 5:33 pm ] |
i've had no problem posting the word Lynx |
Author: | drmini in aust [ Sat Jan 13, 2007 5:39 pm ] |
I had problems this morning, more than 3 lines of text and it denied me access. ![]() ![]() |
Author: | supercharged 850 [ Sat Jan 13, 2007 6:29 pm ] |
sports850 wrote: Yes , same drama's as I had , I can't use that word with a capital L for some reason , the forum thinks I'm giving it an instruction to do something that it's not allowed to do ....
Yep me too..... I was updating an old post which already had the word in it (all in capitals) and it kept giving me a 404 error. I removed the L word and it updated the post without a problem. /end of thread hijack |
Page 1 of 3 | All times are UTC + 10 hours |
