what mods for a turbo head https://www.ausmini.com/forums/viewtopic.php?f=2&t=2677 |
Author: | minimarc [ Fri Nov 05, 2004 8:42 pm ] |
Post subject: | what mods for a turbo head |
what needs to be done to take a say 12G940 head to being a head able to be used on a turbod engine sodium valves etc are these needed |
Author: | drmini in aust [ Fri Nov 05, 2004 9:38 pm ] |
Post subject: | Re: what mods for a turbo head |
minimarc wrote: what needs to be done to take a say 12G940 head to being a head able to be used on a turbod engine
sodium valves etc are these needed Current thinking is no, not needed- there have been cases in UK lately of the heads coming off sodium filled ones.. ![]() Good race quality S/S ones are the go, according to most turbo jocks. Main mod to a head for turbo use (apart from porting & valves) is get some volume into the chambers. Around 28cc is usually needed (stock is 21.4cc) to get the C/R down to around 8.0:1. |
Author: | gafmo [ Fri Nov 05, 2004 9:55 pm ] |
That's a bog amount of Air ![]() |
Author: | minimarc [ Fri Nov 05, 2004 10:20 pm ] |
s/s stanless steel valves you mean |
Author: | kazjim [ Fri Nov 05, 2004 10:28 pm ] |
Stainless here my friend...... I've got a 12G202 on a 998 Turbo, and I've still got a fair amount to take out of my chambers.... i'm developing it as i go..... The main aim is to minimise detonation, while maximising chamber filling.... I'm going to remove the "beak" next time, i still feel that its a "hot-spot" ..... Good Luck!! J |
Author: | gafmo [ Fri Nov 05, 2004 10:34 pm ] |
kazjim wrote: Stainless here my friend......
I've got a 12G202 on a 998 Turbo, and I've still got a fair amount to take out of my chambers.... i'm developing it as i go..... The main aim is to minimise detonation, while maximising chamber filling.... I'm going to remove the "beak" next time, i still feel that its a "hot-spot" ..... Good Luck!! J A turdo on a standed head 202head ![]() The beak must go, even, the beak is removed from Sue' s standed 202 non turbo ![]() ![]() |
Author: | minimarc [ Fri Nov 05, 2004 10:39 pm ] |
mnmn interesting stainless steel valves double valve springs im quessing |
