It is currently Sat Jul 26, 2025 4:58 pm
 Post subject: masking tape
PostPosted: Tue Oct 16, 2007 5:30 pm
ok itaped up my doors a while ago with masking tape the chrome around the outside of the door...now the stupid stuff is proving hard to getoff and metho doesnt help much either..........any help will be appreciated
cheers justin
PostPosted: Tue Oct 16, 2007 5:31 pm
Turps will dissolve the glue a lot better than metho.
PostPosted: Tue Oct 16, 2007 5:32 pm
turps...ok does it do anythin to your paint?
PostPosted: Tue Oct 16, 2007 5:34 pm
Nope, not unless it is wet. Takes bugs off quite nicely too, and remove contact cement
PostPosted: Tue Oct 16, 2007 5:35 pm
ok cool......thanks for the tip :wink:
PostPosted: Tue Oct 16, 2007 5:59 pm
If that fails you can get adhesive plaster remover, designed to get the sticky stuff left when you take sticking plaster off your skin. Works great for all sorts of sticky labels. You can get it at chemists.
Pete
PostPosted: Tue Oct 16, 2007 6:00 pm
Or if you are very careful where it goes acetone as the last resort :wink:
David L
 Post subject: Tape
PostPosted: Tue Oct 16, 2007 6:11 pm
Buy some wax and grease remover it will get it of.
Steve
Classic Not Plastic
PostPosted: Tue Oct 16, 2007 7:23 pm
3M make an aerosol adhesive remover which works really well to. But yeah just get some K&H wax n grease remover. (much cheaper)
PostPosted: Tue Oct 16, 2007 7:34 pm
ok ill see what i can do thanks fellas
PostPosted: Tue Oct 16, 2007 7:43 pm
In future when your masking stuff up on your car, use this stuff please.
PostPosted: Tue Oct 16, 2007 7:46 pm
ok where ya get that stuff from......and is it dearer then maskin tape
PostPosted: Tue Oct 16, 2007 7:54 pm
Bout $12-$15 per roll. I got mine from bunnings, otherwise a paint shop will stock it. Its very low tack. It comes off without leaving a mark
Even if you do this, it comes off cleanly:
PostPosted: Tue Oct 16, 2007 8:01 pm
Why did you do that?
PostPosted: Tue Oct 16, 2007 8:05 pm
To fit in with the rice racing guys.......
Nah i bought my ute from the Gold Coast and drove it 2000klm home to Cairns. I didnt feel like getting stone chips and bugs splattered over the front of the car. This did a really great job!!!! Cost me $24 compared to $300 for a Car Bra.
