It is currently Sat Jul 19, 2025 4:33 pm
PostPosted: Fri Jan 19, 2007 5:09 pm
Hi
As the title says, is the white knights "apline green" an engine enamel?
I was told in another post that it is a similar colour to the original engine colour. Also where can i get it from?
Cheers Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri Jan 19, 2007 5:12 pm
Slow-Po
PM 2 S's & a Clubman, I believe that White Knight gives him a $1 for every can sold. :wink:
EDIT - according to this thread, Bunnings
http://www.ausmini.com/forums/viewtopic ... c&start=30
PostPosted: Fri Jan 19, 2007 6:06 pm
its not engine enamel, but it doesn't matter - clean the block properly and etch prime it, and it'll be good. No need for fancy engine paint...
PostPosted: Fri Jan 19, 2007 6:24 pm
Engine blocks and heads seldom get past 100C anyway. :wink:
PostPosted: Fri Jan 19, 2007 6:34 pm
That's what I've got as well, holds well and is easy to replace when touch ups or additions are needed to be painted
PostPosted: Fri Jan 19, 2007 6:46 pm
So its just the normal white knight paint in a spray can called alpine green?
Where do i get it? Bunnings?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Fri Jan 19, 2007 7:03 pm
I couldn't find Alpine Green in the colour chart at Bunnys so I got Forest Sage in the Dulux brand who also make White Knight and someone on here mentioned it was the same colour.
David L
PostPosted: Fri Jan 19, 2007 7:28 pm
Alpine Green is available in White Night as a hammered finish. It was available in flat, but I can't see it on their website.
http://www.whiteknightpaints.com.au/product_colour/image/84/AlpineGreen.gif?1148629651
PostPosted: Fri Jan 19, 2007 7:38 pm
I looked at the web site and the only appline green i can find is in the rust gaurd type paint, is this the one?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Fri Jan 19, 2007 8:03 pm
Die Die Die!!
i used hammertone, alpine green by white night... straight on the cleaned block, works a treat.. easy to get it good and easy to touch up :) hammertone is great :)
PostPosted: Fri Jan 19, 2007 9:19 pm
ryan
thats the one
got some from our local wattyl paint shop last week
PostPosted: Sat Jan 20, 2007 12:22 am
You may find the rust guard tougher. I used to restore stationary engines as a kid, and the best stuff I ever used was killrust. 8)
Users browsing this forum: Bing [Bot], watsupskip and 75 guests
