It is currently Fri Aug 01, 2025 9:54 pm
PostPosted: Sun Jan 21, 2007 3:39 pm
High heel ninja
My Rover engined clubby has spat the gearbox dummy, no forward gears only reverse, where in Sydney can i buy the clutch plates & how much?
Doogie
PostPosted: Sun Jan 21, 2007 3:56 pm
Morris Minor World, Barney St, Nth Parramatta.
Brad paid about $82 total recently for 2 fwd clutch plates, the gasket, and a front gasket too (so we could adjust the bands).
I have the special service tool (copy of) to hold the clutch assembly in place whilst cover is refitted.
You're welcome to borrow it. :wink:
Automatic box stripping details are all in the Leyland Black Book.
PostPosted: Sun Jan 21, 2007 3:58 pm
High heel ninja
Thanks Kev, much appreciated
Doogie
PostPosted: Sun Jan 21, 2007 5:11 pm
Are these special order parts or anything complicated?
Just wondering if I should order a set of those bits to keep on the shelf
for a rainy day?
:D
PostPosted: Sun Jan 21, 2007 5:38 pm
No they do normally stock them, these plates are the first thing that wears out on a `matic box usually.
It's possible to modify the fwd clutch assembly to take 3 plates not 2.
Also, if you use the latest top/reverse clutch plates instead, they have kevlar facing.
See http://www.austinamericausa.com/ and click on `technical advice'.
:wink:
